PowerBook G4 Titanium DVI Airport Card Replacement
    1. PowerBook G4 Titanium DVI Airport Card Replacement, Battery: step 1, image 1 of 2 PowerBook G4 Titanium DVI Airport Card Replacement, Battery: step 1, image 2 of 2
      • Locate the battery release tab on the underside of the G4.
      • Slide the battery release tab to the left and lift the battery out of the computer.
      Ask FixBot
    1. PowerBook G4 Titanium DVI Airport Card Replacement, Lower Case: step 2, image 1 of 2 PowerBook G4 Titanium DVI Airport Card Replacement, Lower Case: step 2, image 2 of 2
      • Remove the seven T8 Torx screws from the lower case.
      • Using your thumbs, slide the lower case toward the front of the computer.
      • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
      • Lift the lower case off.
      Ask FixBot
    1. PowerBook G4 Titanium DVI Airport Card Replacement, Airport Card: step 3, image 1 of 1
      • Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
      • Disconnect the antenna cable from the left side of the Airport card.
      Ask FixBot
19 other people completed this guide.
Attached Documents
iRobot
1 Reputation
632 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 69
All Time: 23,293
