PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement
    1. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, Battery: step 1, image 1 of 2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, Battery: step 1, image 2 of 2
      • Use your thumbs to push the two battery retaining tabs away from the battery.
      • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
      Ask FixBot
    1. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, Memory Door: step 2, image 1 of 1
      • Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
      Ask FixBot
    2. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement: step 3, image 1 of 2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement: step 3, image 2 of 2
      • Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
      Ask FixBot
    1. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, RAM: step 4, image 1 of 3 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, RAM: step 4, image 2 of 3 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, RAM: step 4, image 3 of 3
      • Use your fingertips to pull the two RAM arms away from the sides of the RAM chip. The chip should pop up slightly.
      • Pull the RAM chip away from its socket and remove it from the logic board.
      • Repeat this process for the other RAM chip, if present.
      Ask FixBot
24 other people completed this guide.
Attached Documents
1 Guide Comment
What is the maximum ram that I can bump up this system to?
Legendary Ocelot - Reply Share
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 41
All Time: 8,953
