PowerBook G4 Aluminum 15" 1.5-1.67 GHz RAM Replacement
  1. PowerBook G4 Aluminum 15" 1.5-1.67 GHz RAM Replacement, Remove the battery: step 1, image 1 of 1
    • Use a coin or a spudger to turn the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
    Ask FixBot
  2. PowerBook G4 Aluminum 15" 1.5-1.67 GHz RAM Replacement, RAM: step 2, image 1 of 1
    • Remove the four Phillips screws from the memory door.
    • Slide the memory door away from the memory compartment.
    Ask FixBot
  3. PowerBook G4 Aluminum 15" 1.5-1.67 GHz RAM Replacement: step 3, image 1 of 1
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the chip directly out from its connectors. If there is a second RAM chip installed, pop it out in the same manner.
    Ask FixBot
19 other people completed this guide.
Attached Documents
iRobot
1 Reputation
636 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 58
All Time: 18,220
