Up to 20% off select tools
This guide has more recent changes. Switch to the latest unverified version.
PowerBook G3 Wallstreet Modem Replacement
Views: 4.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
87
All Time:
4,218
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Easy
Needs More Images
A few more images would make this guide's procedures crystal clear.
Parts
Tools
Introduction
Go to step 1 ↓
If your Wallstreet was one of the few that didn't come with a modem, it's easy to install one.
    1. PowerBook G3 Wallstreet Modem Replacement, Keyboard: step 1, image 1 of 1
      • Remove both expansion bay modules using the levers on the front of the computer.
      • Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
      • Pull the tabs toward yourself and the keyboard will pop up.
      Ask FixBot
    2. PowerBook G3 Wallstreet Modem Replacement: step 2, image 1 of 1
      • Pull the keyboard forward to disengage the tabs holding it in back and rotate it toward you.
      • Rest the keyboard on the trackpad.
      Ask FixBot
      • This is a diagram of the ribbon clamp connectors you will disconnect in the next step.
      • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
      • 2) After disengaging the locking bar, slide the cable out of the connector.
      Ask FixBot
    3. PowerBook G3 Wallstreet Modem Replacement: step 4, image 1 of 1
      • Disconnect the two keyboard connectors by disengaging the clamps and pulling the ribbons directly upward.
      Ask FixBot
    4. PowerBook G3 Wallstreet Modem Replacement: step 5, image 1 of 1
      • Slide a spudger downward between each plastic strain relief cable and the wall of the case in order to bow out the cable beyond the small tab holding it in place.
      • Once the strain relief cables are free, lift the keyboard off.
      Ask FixBot
    5. PowerBook G3 Wallstreet Modem Replacement: step 6, image 1 of 1
      • Your laptop should look approximately like this.
      Ask FixBot
    1. PowerBook G3 Wallstreet Modem Replacement, Heat Shield: step 7, image 1 of 1
      • Remove the two Phillips screws from the heat shield.
      • One screw is shorter than the other. When putting the Wallstreet back together, this screw goes in the middle of the heat shield.
      Ask FixBot
    2. PowerBook G3 Wallstreet Modem Replacement: step 8, image 1 of 1
      • Grasp the metal handle on the heat shield and pull up and toward yourself.
      Ask FixBot
    1. PowerBook G3 Wallstreet Modem Replacement, Hard Drive: step 9, image 1 of 1
      • Unscrew, but do not remove, the single Phillips screw from the hard drive bracket.
      Ask FixBot
    2. PowerBook G3 Wallstreet Modem Replacement: step 10, image 1 of 1
      • Grasp the hard drive bracket on the left side and pull up and to the left.
      Ask FixBot
    3. PowerBook G3 Wallstreet Modem Replacement: step 11, image 1 of 1
      Ask FixBot
    1. PowerBook G3 Wallstreet Modem Replacement, Processor: step 12, image 1 of 1
      • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
      • Remove the processor by sliding it up and to the right.
      • The processor and RAM can be removed as a unit. It is not necessary to remove the RAM from the processor.
      • There are two tabs on the left side of the processor that fit into slots on the metal framework. Make sure these tabs are in the slots.
      Ask FixBot
    1. PowerBook G3 Wallstreet Modem Replacement, Modem: step 13, image 1 of 1
      • Remove the single Phillips screw from the modem.
      • Disconnect the orange PMU cable by pulling it directly up.
      Ask FixBot
    2. PowerBook G3 Wallstreet Modem Replacement: step 14, image 1 of 1
      • Disconnect the modem from the logic board by lifting up on the right side using a spudger, the tip of your finger, or a flat non-metal tool.
      • Remove the modem by sliding it up and to the right.
      Ask FixBot
    3. PowerBook G3 Wallstreet Modem Replacement: step 15, image 1 of 1
      Ask FixBot
2 other people completed this guide.
Attached Documents
Author
with
iRobot
1 Reputation
632 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 87
All Time: 4,218
