PowerBook G3 Pismo Sound Card Replacement
Views: 12K
View statistics:
Past 24 Hours:
5
Past 7 Days:
26
Past 30 Days:
98
All Time:
12,121
Comments: 6
4 comments on steps, 2 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Difficult
Introduction
Go to step 1 ↓
Tripped over your power cord? Well, at least you don't have to replace the entire logic board.
Parts
Tools
    1. PowerBook G3 Pismo Sound Card Replacement, Keyboard: step 1, image 1 of 1
      • Turn the keyboard locking screw so that it is parallel to the space bar.
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
      Ask FixBot
    2. PowerBook G3 Pismo Sound Card Replacement: step 2, image 1 of 1
      • Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
      • The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
      • Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
      Ask FixBot
    3. PowerBook G3 Pismo Sound Card Replacement: step 3, image 1 of 1
      • Your laptop should look approximately like this.
      Ask FixBot
    1. PowerBook G3 Pismo Sound Card Replacement, Heat Shield: step 4, image 1 of 1
      • Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
      • Lift the heat shield up and pull it toward you.
      Ask FixBot
    2. PowerBook G3 Pismo Sound Card Replacement: step 5, image 1 of 1
      Ask FixBot
    1. PowerBook G3 Pismo Sound Card Replacement, Airport Card: step 6, image 1 of 1
      • Skip this step if your computer does not have an Airport card installed.
      • Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
      • The Airport card is still attached to the antenna cable, so don't just yank it out of the slot.
      Ask FixBot
    2. PowerBook G3 Pismo Sound Card Replacement: step 7, image 1 of 1
      • Disconnect the antenna cable from the Airport card.
      Ask FixBot
    1. PowerBook G3 Pismo Sound Card Replacement, PRAM Battery: step 8, image 1 of 1
      • Pull the battery cable directly up from the logic board.
      • Remove the battery from its holder by pulling up and to the left.
      Ask FixBot
    2. PowerBook G3 Pismo Sound Card Replacement: step 9, image 1 of 1
      Ask FixBot
    1. PowerBook G3 Pismo Sound Card Replacement, Heat Sink: step 10, image 1 of 1
      • Remove the long silver Phillips #1 screw from the heat sink.
      • Remove the two T8 Torx screws that attach the heat sink to the processor.
      Ask FixBot
    2. PowerBook G3 Pismo Sound Card Replacement: step 11, image 1 of 1
      • Lift the heat sink up from the left side and pull it out.
      • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
      Ask FixBot
    1. PowerBook G3 Pismo Sound Card Replacement, Processor: step 12, image 1 of 1
      • Grasp the plastic tab on the processor's right side and pull it directly up.
      • Some processors may be missing the plastic pull tab. In this case, we suggest using a non-metal tool to gently pry up the processor. Slip the tool's thin edge under the front right corner of the processor and carefully pry it up.
      Ask FixBot
    2. PowerBook G3 Pismo Sound Card Replacement: step 13, image 1 of 1
      Ask FixBot
    1. PowerBook G3 Pismo Sound Card Replacement, Modem: step 14, image 1 of 1
      • Remove the black Torx screw from the right side of the modem.
      • Remove the small black plastic rectangle with four holes.
      Ask FixBot
    2. PowerBook G3 Pismo Sound Card Replacement: step 15, image 1 of 1
      • Use the tips of your fingers, a spudger, or a flat non-metal tool to get under the modem's edge and pry it up from its socket.
      Ask FixBot
    3. PowerBook G3 Pismo Sound Card Replacement: step 16, image 1 of 1
      • Disconnect the cable from the right side of the modem.
      Ask FixBot
    1. PowerBook G3 Pismo Sound Card Replacement, Hard Drive: step 17, image 1 of 1
      • Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
      • Try to grasp the cable on the plastic connector rather than on the flexible cable section.
      Ask FixBot
    2. PowerBook G3 Pismo Sound Card Replacement: step 18, image 1 of 1
      • Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
      Ask FixBot
    3. PowerBook G3 Pismo Sound Card Replacement: step 19, image 1 of 1
      Ask FixBot
    1. PowerBook G3 Pismo Sound Card Replacement, Clutch Cover: step 20, image 1 of 1
      • Push the display back so that it lies flat.
      • Slip your index finger or a nylon tool under the clutch cover near the power button and pull gently upward until you feel it come free.
      • Repeat the previous step on the left side.
      Ask FixBot
    2. PowerBook G3 Pismo Sound Card Replacement: step 21, image 1 of 1
      • Lift the clutch cover up and off, rotating it toward yourself.
      Ask FixBot
    1. PowerBook G3 Pismo Sound Card Replacement, Inverter: step 22, image 1 of 1
      • Grasp the orange display data cable and disconnect it from the logic board.
      Ask FixBot
    2. PowerBook G3 Pismo Sound Card Replacement: step 23, image 1 of 1
      • Remove the single black Torx screw that fastens the display cable to the plastic casing.
      • Grasp the thin display inverter board at its left end; lift up and rotate toward yourself.
      • There are two tabs that hold the display inverter in place; these are what you need to get past in order to pull the board free.
      Ask FixBot
    3. PowerBook G3 Pismo Sound Card Replacement: step 24, image 1 of 1
      • Disconnect the white inverter cable from the right end of the board
      Ask FixBot
    4. PowerBook G3 Pismo Sound Card Replacement: step 25, image 1 of 1
      • Disconnect the inverter plug, pulling directly up from the logic board.
      Ask FixBot
    1. PowerBook G3 Pismo Sound Card Replacement, Display: step 26, image 1 of 1
      • Turn the laptop around so that its back faces you.
      • Open the port door located at the back of the laptop.
      • Remove the four black Torx screws.
      Ask FixBot
    2. PowerBook G3 Pismo Sound Card Replacement: step 27, image 1 of 1
      • Returning to the front, pull the black Airport antenna up from its recessed housing.
      Ask FixBot
      • Hold the display on both sides and pull directly up until its hinges are free of their mounts.
      Ask FixBot
    3. PowerBook G3 Pismo Sound Card Replacement: step 29, image 1 of 1
      Ask FixBot
    1. PowerBook G3 Pismo Sound Card Replacement, Upper Case: step 30, image 1 of 1
      • Disconnect the wide orange cable that connects the airport card slot to the logic board.
      Ask FixBot
    2. PowerBook G3 Pismo Sound Card Replacement: step 31, image 1 of 1
      • Remove the three long silver and one short black Torx screws from the beige plastic casing.
      Ask FixBot
    3. PowerBook G3 Pismo Sound Card Replacement: step 32, image 1 of 1
      • Slide the thin plastic shield away from you, out from under the black casing.
      • Disconnect the newly revealed thin orange ribbon from the logic board.
      • Remove the two long silver Torx screws.
      Ask FixBot
    4. PowerBook G3 Pismo Sound Card Replacement: step 33, image 1 of 1
      • Turn the laptop over.
      • Remove the five short Torx screws from the bottom casing.
      • Remove the two long Torx screws in the front left and front right corners; make sure to put these back in the proper place when reassembling.
      Ask FixBot
    5. PowerBook G3 Pismo Sound Card Replacement: step 34, image 1 of 1
      • Turn the laptop back over.
      • Remove three short black Torx screws from the metal frame.
      • Remove the small Torx screw to the far left that fastens the logic board to the casing.
      Ask FixBot
    6. PowerBook G3 Pismo Sound Card Replacement: step 35, image 1 of 1
      • Grasp the upper plastic casing where it locks into the internal frame and pull back. When the plastic tab has cleared the slot that the casing locks into, pull up enough to keep it from locking back into place.
      Ask FixBot
    7. PowerBook G3 Pismo Sound Card Replacement: step 36, image 1 of 1
      • The PC card eject button on the laptop's left side prevents the upper casing from lifting up. In order to bypass the button, push it in far enough so that you can pull the upper casing's left side out and up beyond the button.
      Ask FixBot
    8. PowerBook G3 Pismo Sound Card Replacement: step 37, image 1 of 1
      • Lift the left side of the case partly up so that you can access and disconnect the audio in/out cables from the sound card in the upper right of the case.
      • Be careful not to lift the upper casing too far before you have disconnected the audio in/out cables or you may damage the sound card.
      • Remove the upper casing. Note that there are two tabs on the laptop's front that often cause the upper case to stick.
      Ask FixBot
    9. PowerBook G3 Pismo Sound Card Replacement: step 38, image 1 of 1
      Ask FixBot
    1. PowerBook G3 Pismo Sound Card Replacement, Power Card: step 39, image 1 of 1
      • Remove the two long silver Torx screws from the power card in the center of the laptop
      Ask FixBot
    2. PowerBook G3 Pismo Sound Card Replacement: step 40, image 1 of 1
      • Grasp the power card near the black shield and lift up.
      Ask FixBot
    1. PowerBook G3 Pismo Sound Card Replacement, I/O EMI Shield: step 41, image 1 of 1
      • Gently clasp the left side of the metal shield between your thumb and forefinger and carefully pull up and toward the front of the laptop.
      • Be very careful when removing the leftmost clip on the EMI Shield from its slot, as this piece will bend very easily. This is one of the easiest parts to damage in the Pismo.
      Ask FixBot
    1. PowerBook G3 Pismo Sound Card Replacement, Framework: step 42, image 1 of 1
      • Remove the single short black Torx screw anchoring the metal framework to the lower casing.
      • Use needle-nose pliers or a five millimeter nut driver to remove the small metal nut from the bolt.
      • If you're using pliers, be extremely careful not to let them slip or you may damage the logic board.
      Ask FixBot
      • Disconnect the fan cable from the left side of the logic board.
      Ask FixBot
    2. PowerBook G3 Pismo Sound Card Replacement: step 44, image 1 of 1
      • Turn the laptop so that its back is facing you.
      • Lift up on the left side of the metal framework and remove the single black Torx screw.
      Ask FixBot
    3. PowerBook G3 Pismo Sound Card Replacement: step 45, image 1 of 1
      • Grasp the EMI Filter by its black end and rotate it toward the front of the laptop. Pull the filter up and beyond the screw bracket.
      • Remove the metal framework.
      Ask FixBot
    4. PowerBook G3 Pismo Sound Card Replacement: step 46, image 1 of 1
      Ask FixBot
    1. PowerBook G3 Pismo Sound Card Replacement, Sound Card: step 47, image 1 of 1
      • Lift the sound card out by pulling up on both the right and left sides.
      • If the sound card sticks, pull the black metal wall of the casing toward you while lifting the right side of the sound card up.
      Ask FixBot
5 other people completed this guide.
Attached Documents
iRobot
1 Reputation
632 Guides authored
2 Guide Comments
I recently was trying to replace the hard drive in my Pismo, but didn't unplug the computer. I didn't realize this until after I'd taken out the hard drive. The result was that the computer would not start. The hard drive wouldn't start spinning, there was no startup chime. I replaced the sound card and now it boots and runs fine.
prax5487 - Reply Share
Removing the Torx screw in step 34, the fan cable and the nut in step 42 is completely unnecessary as you are not removing the logic board in order to get to the sound card.
Tryk - Reply Share
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 98
All Time: 12,121
