PowerBook G3 Pismo PRAM Battery Replacement
    1. PowerBook G3 Pismo PRAM Battery Replacement, Keyboard: step 1, image 1 of 1
      • Turn the keyboard locking screw so that it is parallel to the space bar.
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
      Ask FixBot
    2. PowerBook G3 Pismo PRAM Battery Replacement: step 2, image 1 of 1
      • Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
      • The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
      • Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
      Ask FixBot
    3. PowerBook G3 Pismo PRAM Battery Replacement: step 3, image 1 of 1
      • Your laptop should look approximately like this.
      Ask FixBot
    1. PowerBook G3 Pismo PRAM Battery Replacement, Heat Shield: step 4, image 1 of 1
      • Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
      • Lift the heat shield up and pull it toward you.
      Ask FixBot
    2. PowerBook G3 Pismo PRAM Battery Replacement: step 5, image 1 of 1
      Ask FixBot
    1. PowerBook G3 Pismo PRAM Battery Replacement, Airport Card: step 6, image 1 of 1
      • Skip this step if your computer does not have an Airport card installed.
      • Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
      • The Airport card is still attached to the antenna cable, so don't just yank it out of the slot.
      Ask FixBot
    2. PowerBook G3 Pismo PRAM Battery Replacement: step 7, image 1 of 1
      • Disconnect the antenna cable from the Airport card.
      Ask FixBot
    1. PowerBook G3 Pismo PRAM Battery Replacement, PRAM Battery: step 8, image 1 of 1
      • Pull the battery cable directly up from the logic board.
      • Remove the battery from its holder by pulling up and to the left.
      Ask FixBot
    2. PowerBook G3 Pismo PRAM Battery Replacement: step 9, image 1 of 1
      Ask FixBot
27 other people completed this guide.
Attached Documents
iRobot
1 Reputation
632 Guides authored
6 Guide Comments
Frankly speaking I do not have idea why do I need steps 2-7 to replace battery? Why I can't go directly to step 8 if it is possible? BTW - the battery seems to be composed from 4 standard batteries. Is anyone aware how to assembly new battery? It is not available as spare part (616-0108)
Tomek - Reply Share
Agreed, I just successfully removed my PRAM battery skipping all those steps, just popped the keyboard out, removed the DVD drive from the right-hand out and popped that bad boy out, no problemo.
Edward Gain - Reply Share
I read that you "removed the DVD drive from the right-hand out...." I'm baffled as to what you mean or how that is done. Can you explain that step?
Scott Kohanek - Reply Share
Why do I need to remove the airport card? It's just like telling somebody to remove their shoes to take off their hat?
christopher Ng - Reply Share
Wish I had read the comments before proceeding. Just removed the Airport card and put it back in for no reason. Thanks for the instructions though.
j.boersma - Reply Share
Past 24 Hours: 0
Past 7 Days: 17
Past 30 Days: 73
All Time: 42,276
