PowerBook G3 Pismo PC Card Cage Replacement
  1. PowerBook G3 Pismo PC Card Cage Replacement, Keyboard: step 1, image 1 of 1
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
    Ask FixBot
  2. PowerBook G3 Pismo PC Card Cage Replacement: step 2, image 1 of 1
    • Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
    • The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
    • Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
    Ask FixBot
  3. PowerBook G3 Pismo PC Card Cage Replacement: step 3, image 1 of 1
    • Your laptop should look approximately like this.
    Ask FixBot
  4. PowerBook G3 Pismo PC Card Cage Replacement, Heat Shield: step 4, image 1 of 1
    • Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
    • Lift the heat shield up and pull it toward you.
    Ask FixBot
  5. PowerBook G3 Pismo PC Card Cage Replacement: step 5, image 1 of 1
    Ask FixBot
  6. PowerBook G3 Pismo PC Card Cage Replacement, Airport Card: step 6, image 1 of 1
    • Skip this step if your computer does not have an Airport card installed.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
    • The Airport card is still attached to the antenna cable, so don't just yank it out of the slot.
    Ask FixBot
  7. PowerBook G3 Pismo PC Card Cage Replacement: step 7, image 1 of 1
    • Disconnect the antenna cable from the Airport card.
    Ask FixBot
  8. PowerBook G3 Pismo PC Card Cage Replacement, PRAM Battery: step 8, image 1 of 1
    • Pull the battery cable directly up from the logic board.
    • Remove the battery from its holder by pulling up and to the left.
    Ask FixBot
  9. PowerBook G3 Pismo PC Card Cage Replacement: step 9, image 1 of 1
    Ask FixBot
  10. PowerBook G3 Pismo PC Card Cage Replacement, Heat Sink: step 10, image 1 of 1
    • Remove the long silver Phillips #1 screw from the heat sink.
    • Remove the two T8 Torx screws that attach the heat sink to the processor.
    Ask FixBot
  11. PowerBook G3 Pismo PC Card Cage Replacement: step 11, image 1 of 1
    • Lift the heat sink up from the left side and pull it out.
    • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
    Ask FixBot
  12. PowerBook G3 Pismo PC Card Cage Replacement, Processor: step 12, image 1 of 1
    • Grasp the plastic tab on the processor's right side and pull it directly up.
    • Some processors may be missing the plastic pull tab. In this case, we suggest using a non-metal tool to gently pry up the processor. Slip the tool's thin edge under the front right corner of the processor and carefully pry it up.
    Ask FixBot
  13. PowerBook G3 Pismo PC Card Cage Replacement: step 13, image 1 of 1
    Ask FixBot
  14. PowerBook G3 Pismo PC Card Cage Replacement, Modem: step 14, image 1 of 1
    • Remove the black Torx screw from the right side of the modem.
    • Remove the small black plastic rectangle with four holes.
    Ask FixBot
  15. PowerBook G3 Pismo PC Card Cage Replacement: step 15, image 1 of 1
    • Use the tips of your fingers, a spudger, or a flat non-metal tool to get under the modem's edge and pry it up from its socket.
    Ask FixBot
  16. PowerBook G3 Pismo PC Card Cage Replacement: step 16, image 1 of 1
    • Disconnect the cable from the right side of the modem.
    Ask FixBot
  17. PowerBook G3 Pismo PC Card Cage Replacement, Hard Drive: step 17, image 1 of 1
    • Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
    • Try to grasp the cable on the plastic connector rather than on the flexible cable section.
    Ask FixBot
  18. PowerBook G3 Pismo PC Card Cage Replacement: step 18, image 1 of 1
    • Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
    Ask FixBot
  19. PowerBook G3 Pismo PC Card Cage Replacement: step 19, image 1 of 1
    Ask FixBot
  20. PowerBook G3 Pismo PC Card Cage Replacement, Clutch Cover: step 20, image 1 of 1
    • Push the display back so that it lies flat.
    • Slip your index finger or a nylon tool under the clutch cover near the power button and pull gently upward until you feel it come free.
    • Repeat the previous step on the left side.
    Ask FixBot
  21. PowerBook G3 Pismo PC Card Cage Replacement: step 21, image 1 of 1
    • Lift the clutch cover up and off, rotating it toward yourself.
    Ask FixBot
  22. PowerBook G3 Pismo PC Card Cage Replacement, Inverter: step 22, image 1 of 1
    • Grasp the orange display data cable and disconnect it from the logic board.
    Ask FixBot
  23. PowerBook G3 Pismo PC Card Cage Replacement: step 23, image 1 of 1
    • Remove the single black Torx screw that fastens the display cable to the plastic casing.
    • Grasp the thin display inverter board at its left end; lift up and rotate toward yourself.
    • There are two tabs that hold the display inverter in place; these are what you need to get past in order to pull the board free.
    Ask FixBot
  24. PowerBook G3 Pismo PC Card Cage Replacement: step 24, image 1 of 1
    • Disconnect the white inverter cable from the right end of the board
    Ask FixBot
  25. PowerBook G3 Pismo PC Card Cage Replacement: step 25, image 1 of 1
    • Disconnect the inverter plug, pulling directly up from the logic board.
    Ask FixBot
  26. PowerBook G3 Pismo PC Card Cage Replacement, Display: step 26, image 1 of 1
    • Turn the laptop around so that its back faces you.
    • Open the port door located at the back of the laptop.
    • Remove the four black Torx screws.
    Ask FixBot
  27. PowerBook G3 Pismo PC Card Cage Replacement: step 27, image 1 of 1
    • Returning to the front, pull the black Airport antenna up from its recessed housing.
    Ask FixBot
    • Hold the display on both sides and pull directly up until its hinges are free of their mounts.
    Ask FixBot
  28. PowerBook G3 Pismo PC Card Cage Replacement: step 29, image 1 of 1
    Ask FixBot
  29. PowerBook G3 Pismo PC Card Cage Replacement, Upper Case: step 30, image 1 of 1
    • Disconnect the wide orange cable that connects the airport card slot to the logic board.
    Ask FixBot
  30. PowerBook G3 Pismo PC Card Cage Replacement: step 31, image 1 of 1
    • Remove the three long silver and one short black Torx screws from the beige plastic casing.
    Ask FixBot
  31. PowerBook G3 Pismo PC Card Cage Replacement: step 32, image 1 of 1
    • Slide the thin plastic shield away from you, out from under the black casing.
    • Disconnect the newly revealed thin orange ribbon from the logic board.
    • Remove the two long silver Torx screws.
    Ask FixBot
  32. PowerBook G3 Pismo PC Card Cage Replacement: step 33, image 1 of 1
    • Turn the laptop over.
    • Remove the five short Torx screws from the bottom casing.
    • Remove the two long Torx screws in the front left and front right corners; make sure to put these back in the proper place when reassembling.
    Ask FixBot
  33. PowerBook G3 Pismo PC Card Cage Replacement: step 34, image 1 of 1
    • Turn the laptop back over.
    • Remove three short black Torx screws from the metal frame.
    • Remove the small Torx screw to the far left that fastens the logic board to the casing.
    Ask FixBot
  34. PowerBook G3 Pismo PC Card Cage Replacement: step 35, image 1 of 1
    • Grasp the upper plastic casing where it locks into the internal frame and pull back. When the plastic tab has cleared the slot that the casing locks into, pull up enough to keep it from locking back into place.
    Ask FixBot
  35. PowerBook G3 Pismo PC Card Cage Replacement: step 36, image 1 of 1
    • The PC card eject button on the laptop's left side prevents the upper casing from lifting up. In order to bypass the button, push it in far enough so that you can pull the upper casing's left side out and up beyond the button.
    Ask FixBot
  36. PowerBook G3 Pismo PC Card Cage Replacement: step 37, image 1 of 1
    • Lift the left side of the case partly up so that you can access and disconnect the audio in/out cables from the sound card in the upper right of the case.
    • Be careful not to lift the upper casing too far before you have disconnected the audio in/out cables or you may damage the sound card.
    • Remove the upper casing. Note that there are two tabs on the laptop's front that often cause the upper case to stick.
    Ask FixBot
  37. PowerBook G3 Pismo PC Card Cage Replacement: step 38, image 1 of 1
    Ask FixBot
  38. PowerBook G3 Pismo PC Card Cage Replacement, Power Card: step 39, image 1 of 1
    • Remove the two long silver Torx screws from the power card in the center of the laptop
    Ask FixBot
  39. PowerBook G3 Pismo PC Card Cage Replacement: step 40, image 1 of 1
    • Grasp the power card near the black shield and lift up.
    Ask FixBot
  40. PowerBook G3 Pismo PC Card Cage Replacement, I/O EMI Shield: step 41, image 1 of 1
    • Gently clasp the left side of the metal shield between your thumb and forefinger and carefully pull up and toward the front of the laptop.
    • Be very careful when removing the leftmost clip on the EMI Shield from its slot, as this piece will bend very easily. This is one of the easiest parts to damage in the Pismo.
    Ask FixBot
  41. PowerBook G3 Pismo PC Card Cage Replacement, Framework: step 42, image 1 of 1
    • Remove the single short black Torx screw anchoring the metal framework to the lower casing.
    • Use needle-nose pliers or a five millimeter nut driver to remove the small metal nut from the bolt.
    • If you're using pliers, be extremely careful not to let them slip or you may damage the logic board.
    Ask FixBot
    • Disconnect the fan cable from the left side of the logic board.
    Ask FixBot
  42. PowerBook G3 Pismo PC Card Cage Replacement: step 44, image 1 of 1
    • Turn the laptop so that its back is facing you.
    • Lift up on the left side of the metal framework and remove the single black Torx screw.
    Ask FixBot
  43. PowerBook G3 Pismo PC Card Cage Replacement: step 45, image 1 of 1
    • Grasp the EMI Filter by its black end and rotate it toward the front of the laptop. Pull the filter up and beyond the screw bracket.
    • Remove the metal framework.
    Ask FixBot
  44. PowerBook G3 Pismo PC Card Cage Replacement: step 46, image 1 of 1
    Ask FixBot
  45. PowerBook G3 Pismo PC Card Cage Replacement, Sound Card: step 47, image 1 of 1
    • Lift the sound card out by pulling up on both the right and left sides.
    • If the sound card sticks, pull the black metal wall of the casing toward you while lifting the right side of the sound card up.
    Ask FixBot
  46. PowerBook G3 Pismo PC Card Cage Replacement, Logic Board: step 48, image 1 of 1
    • Turn the laptop around so that the front faces you.
    • Move the metal yoke to the left.
    Ask FixBot
  47. PowerBook G3 Pismo PC Card Cage Replacement: step 49, image 1 of 1
    • Gently lift the front edge of the logic board and pull it toward you.
    • There are two major obstacles to avoid when removing the logic board: the first is the fan and connector cables, and the second is the bolt in the back left corner.
    Ask FixBot
  48. PowerBook G3 Pismo PC Card Cage Replacement, PC Card Cage: step 50, image 1 of 1
    • Turn the logic board over so that the ports are facing you.
    • Remove the four Phillips screws holding the PC card cage to the logic board.
    • Two of the screws are short and two are longer. The two short screws go on the side closer to the PC card eject button.
    Ask FixBot
  49. PowerBook G3 Pismo PC Card Cage Replacement: step 51, image 1 of 1
    • Turn the logic board back over.
    • Clasp the PC card cage between your thumb and index finger and lift it directly upward.
    Ask FixBot
5 other people completed this guide.
Attached Documents
iRobot
1 Reputation
636 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 50
All Time: 5,605
