PowerBook G3 Pismo Clutch Cover Replacement
  1. PowerBook G3 Pismo Clutch Cover Replacement, Keyboard: step 1, image 1 of 1
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the track pad.
    Ask FixBot
  2. PowerBook G3 Pismo Clutch Cover Replacement: step 2, image 1 of 1
    • Pull the keyboard ribbon straight up from the logic board. Place the keyboard aside.
    • The connector may be tight. Gently rock the connector from side to side while pulling directly upward to free it. You can use this technique on many of the cards and cables you'll be disconnecting.
    • Make sure you have removed the laptop battery and CD/DVD modules from the expansion bays before proceeding.
    Ask FixBot
  3. PowerBook G3 Pismo Clutch Cover Replacement: step 3, image 1 of 1
    • Your laptop should look approximately like this.
    Ask FixBot
  4. PowerBook G3 Pismo Clutch Cover Replacement, Heat Shield: step 4, image 1 of 1
    • Remove the two silver Phillips #1 screws that attach the heat shield to the internal metal framework.
    • Lift the heat shield up and pull it toward you.
    Ask FixBot
  5. PowerBook G3 Pismo Clutch Cover Replacement: step 5, image 1 of 1
    Ask FixBot
  6. PowerBook G3 Pismo Clutch Cover Replacement, Airport Card: step 6, image 1 of 1
    • Skip this step if your computer does not have an Airport card installed.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and then to the right.
    • The Airport card is still attached to the antenna cable, so don't just yank it out of the slot.
    Ask FixBot
  7. PowerBook G3 Pismo Clutch Cover Replacement: step 7, image 1 of 1
    • Disconnect the antenna cable from the Airport card.
    Ask FixBot
  8. PowerBook G3 Pismo Clutch Cover Replacement, PRAM Battery: step 8, image 1 of 1
    • Pull the battery cable directly up from the logic board.
    • Remove the battery from its holder by pulling up and to the left.
    Ask FixBot
  9. PowerBook G3 Pismo Clutch Cover Replacement: step 9, image 1 of 1
    Ask FixBot
  10. PowerBook G3 Pismo Clutch Cover Replacement, Heat Sink: step 10, image 1 of 1
    • Remove the long silver Phillips #1 screw from the heat sink.
    • Remove the two T8 Torx screws that attach the heat sink to the processor.
    Ask FixBot
  11. PowerBook G3 Pismo Clutch Cover Replacement: step 11, image 1 of 1
    • Lift the heat sink up from the left side and pull it out.
    • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
    Ask FixBot
  12. PowerBook G3 Pismo Clutch Cover Replacement, Processor: step 12, image 1 of 1
    • Grasp the plastic tab on the processor's right side and pull it directly up.
    • Some processors may be missing the plastic pull tab. In this case, we suggest using a non-metal tool to gently pry up the processor. Slip the tool's thin edge under the front right corner of the processor and carefully pry it up.
    Ask FixBot
  13. PowerBook G3 Pismo Clutch Cover Replacement: step 13, image 1 of 1
    Ask FixBot
  14. PowerBook G3 Pismo Clutch Cover Replacement, Modem: step 14, image 1 of 1
    • Remove the black Torx screw from the right side of the modem.
    • Remove the small black plastic rectangle with four holes.
    Ask FixBot
  15. PowerBook G3 Pismo Clutch Cover Replacement: step 15, image 1 of 1
    • Use the tips of your fingers, a spudger, or a flat non-metal tool to get under the modem's edge and pry it up from its socket.
    Ask FixBot
  16. PowerBook G3 Pismo Clutch Cover Replacement: step 16, image 1 of 1
    • Disconnect the cable from the right side of the modem.
    Ask FixBot
  17. PowerBook G3 Pismo Clutch Cover Replacement, Hard Drive: step 17, image 1 of 1
    • Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
    • Try to grasp the cable on the plastic connector rather than on the flexible cable section.
    Ask FixBot
  18. PowerBook G3 Pismo Clutch Cover Replacement: step 18, image 1 of 1
    • Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
    Ask FixBot
  19. PowerBook G3 Pismo Clutch Cover Replacement: step 19, image 1 of 1
    Ask FixBot
  20. PowerBook G3 Pismo Clutch Cover Replacement, Clutch Cover: step 20, image 1 of 1
    • Push the display back so that it lies flat.
    • Slip your index finger or a nylon tool under the clutch cover near the power button and pull gently upward until you feel it come free.
    • Repeat the previous step on the left side.
    Ask FixBot
  21. PowerBook G3 Pismo Clutch Cover Replacement: step 21, image 1 of 1
    • Lift the clutch cover up and off, rotating it toward yourself.
    Ask FixBot
2 other people completed this guide.
Attached Documents
iRobot
1 Reputation
636 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 54
All Time: 5,593
