Up to 20% off select tools
PowerBook Duo 230 Disassembly
Views: 3.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
23
Past 30 Days:
117
All Time:
3,844
Comments: 5
5 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 7 minutes
Difficulty: Easy
Community-Contributed Guide
    1. PowerBook Duo 230 Disassembly, Preparation: step 1, image 1 of 1
      • Place the PowerBook Duo 230 on a clean table and prepare a Torx T8 screwdriver.
      Ask FixBot
    2. PowerBook Duo 230 Disassembly, Battery: step 2, image 1 of 3 PowerBook Duo 230 Disassembly, Battery: step 2, image 2 of 3 PowerBook Duo 230 Disassembly, Battery: step 2, image 3 of 3
      • Push in the button as far as it will go.
      • Press and hold the button then simultaneously slide the battery cover to the left.
      • For greater security, you can now remove the battery.
      Ask FixBot
    3. PowerBook Duo 230 Disassembly, Torx Screws: step 3, image 1 of 1
      • Loosen the 2 Torx screws.
      • The screws are the same.
      Ask FixBot
    4. PowerBook Duo 230 Disassembly, Keyboard Removal: step 4, image 1 of 3 PowerBook Duo 230 Disassembly, Keyboard Removal: step 4, image 2 of 3 PowerBook Duo 230 Disassembly, Keyboard Removal: step 4, image 3 of 3
      • Turn your PowerBook over and open it.
      • Now you have to lift up the keyboard. Lift the keyboard by the upper part.
      Ask FixBot
    5. PowerBook Duo 230 Disassembly, Keyboard Connector: step 5, image 1 of 3 PowerBook Duo 230 Disassembly, Keyboard Connector: step 5, image 2 of 3 PowerBook Duo 230 Disassembly, Keyboard Connector: step 5, image 3 of 3
      • Disconnect the keyboard from the Logicboard.
      • Now you need to move the small levers in every corner up. Be careful, small parts can break easily!
      • Gently pull out the flex cable.
      Ask FixBot
Follow the steps in reverse order to reassemble your device.
2 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
Nils
394 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 117
All Time: 3,844
