PowerBook 3400 M3553 Speaker Panel Replacement
  1. PowerBook 3400 M3553 Speaker Panel Replacement, Battery: step 1, image 1 of 1
    • Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
    Ask FixBot
  2. PowerBook 3400 M3553 Speaker Panel Replacement: step 2, image 1 of 2 PowerBook 3400 M3553 Speaker Panel Replacement: step 2, image 2 of 2
    • Hold the button on the front left side and slide the battery out.
    Ask FixBot
  3. PowerBook 3400 M3553 Speaker Panel Replacement, Keyboard: step 3, image 1 of 1
    • With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
    Ask FixBot
  4. PowerBook 3400 M3553 Speaker Panel Replacement: step 4, image 1 of 3 PowerBook 3400 M3553 Speaker Panel Replacement: step 4, image 2 of 3 PowerBook 3400 M3553 Speaker Panel Replacement: step 4, image 3 of 3
    • Turn the computer over and open the display. You should see that the keyboard is loose.
    • Before attempting to remove the keyboard, note that a ribbon cable connects the keyboard to the logic board. Improper removal may damage your keyboard.
    • Slightly lift the front of the keyboard up, and slide the keyboard towards yourself.
    • Carefully lift the top half of the keyboard and pull it towards yourself.
    Ask FixBot
  5. PowerBook 3400 M3553 Speaker Panel Replacement: step 5, image 1 of 2 PowerBook 3400 M3553 Speaker Panel Replacement: step 5, image 2 of 2
    • Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port.
    • Gently remove the ribbons from its tabs.
    Ask FixBot
  6. PowerBook 3400 M3553 Speaker Panel Replacement, RAM: step 6, image 1 of 2 PowerBook 3400 M3553 Speaker Panel Replacement, RAM: step 6, image 2 of 2
    • Gently wiggle the RAM card to loosen the connection until it pulls free.
    Ask FixBot
  7. PowerBook 3400 M3553 Speaker Panel Replacement, Speaker Panel: step 7, image 1 of 2 PowerBook 3400 M3553 Speaker Panel Replacement, Speaker Panel: step 7, image 2 of 2
    • Disconnect the wires from the port.
    Ask FixBot
  8. PowerBook 3400 M3553 Speaker Panel Replacement: step 8, image 1 of 1
    • Remove the 7mm screw connecting the speaker panel to the computer.
    Ask FixBot
  9. PowerBook 3400 M3553 Speaker Panel Replacement: step 9, image 1 of 2 PowerBook 3400 M3553 Speaker Panel Replacement: step 9, image 2 of 2
    • To detach the speaker panel's ribbon cable, use a plastic opening tool to lift the tabs on both sides of the cable port.
    • Once loose, pull the ribbon cable free.
    Ask FixBot
  10. PowerBook 3400 M3553 Speaker Panel Replacement: step 10, image 1 of 2 PowerBook 3400 M3553 Speaker Panel Replacement: step 10, image 2 of 2
    • Lift the lighting/audio panel from it's bottom corners and pull the panel towards yourself.
    Ask FixBot
Michael Mondragon
397 Reputation
9 Guides authored
Cal Poly, Team 24-59, Amido Spring 2011 Member of Cal Poly, Team 24-59, Amido Spring 2011
CPSU-AMIDO-S11S24G59
4 Members
9 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 29
All Time: 2,231
