Up to 20% off select tools
PowerBook 3400 M3553 RAM Replacement
Views: 3.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
82
All Time:
3,534
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
In order to upgrade your PowerBook's RAM or replace a faulty RAM card you will need first remove the existing RAM card.
    1. PowerBook 3400 M3553 RAM Replacement, Battery: step 1, image 1 of 1
      • Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
      Ask FixBot
    2. PowerBook 3400 M3553 RAM Replacement: step 2, image 1 of 2 PowerBook 3400 M3553 RAM Replacement: step 2, image 2 of 2
      • Hold the button on the front left side and slide the battery out.
      Ask FixBot
    1. PowerBook 3400 M3553 RAM Replacement, Keyboard: step 3, image 1 of 1
      • With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
      Ask FixBot
    2. PowerBook 3400 M3553 RAM Replacement: step 4, image 1 of 3 PowerBook 3400 M3553 RAM Replacement: step 4, image 2 of 3 PowerBook 3400 M3553 RAM Replacement: step 4, image 3 of 3
      • Turn the computer over and open the display. You should see that the keyboard is loose.
      • Before attempting to remove the keyboard, note that a ribbon cable connects the keyboard to the logic board. Improper removal may damage your keyboard.
      • Slightly lift the front of the keyboard up, and slide the keyboard towards yourself.
      • Carefully lift the top half of the keyboard and pull it towards yourself.
      Ask FixBot
    3. PowerBook 3400 M3553 RAM Replacement: step 5, image 1 of 2 PowerBook 3400 M3553 RAM Replacement: step 5, image 2 of 2
      • Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port.
      • Gently remove the ribbons from its tabs.
      Ask FixBot
    1. PowerBook 3400 M3553 RAM Replacement, RAM: step 6, image 1 of 2 PowerBook 3400 M3553 RAM Replacement, RAM: step 6, image 2 of 2
      • Gently wiggle the RAM card to loosen the connection until it pulls free.
      Ask FixBot
To install the new RAM card, follow these steps in reverse order.
2 other people completed this guide.
Author
with
Michael Mondragon
415 Reputation
9 Guides authored
Cal Poly, Team 24-59, Amido Spring 2011 Member of Cal Poly, Team 24-59, Amido Spring 2011
CPSU-AMIDO-S11S24G59
4 Members
108 Guides authored
1 Guide Comment
To reattach the keyboard I found it necessary to keep the kid open and push the keyboard all the way down; otherwise, the screws didn’t engage.
Scott - Reply Share
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 82
All Time: 3,534
