Up to 20% off select tools
PowerBook 3400 M3553 Keyboard Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
78
All Time:
3,060
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Tools
  • Spudger
    4.9
  • TR8 Torx Security Screwdriver
    4.9
Introduction
Go to step 1 ↓
Use this guide to remove and replace the keyboard on your PowerBook 3400 M3553.
Keyboard mishaps can be frustrating, halt productivity, and decrease the usefulness of your device. Whether the keys stop working, there is external damage, or any other issue, removing the keyboard is the first step to repairing your device. Once removed, the keyboard can be cleaned or replaced depending on the extent of the damage.
Before attempting any repairs to your PowerBook, make sure that the device is turned off, disconnected to any power source, and your data is properly backed up.
    1. PowerBook 3400 M3553 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
      Ask FixBot
    2. PowerBook 3400 M3553 Keyboard Replacement: step 2, image 1 of 2 PowerBook 3400 M3553 Keyboard Replacement: step 2, image 2 of 2
      • Hold the button on the front left side and slide the battery out.
      Ask FixBot
    1. PowerBook 3400 M3553 Keyboard Replacement, Keyboard: step 3, image 1 of 1
      • With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
      Ask FixBot
    2. PowerBook 3400 M3553 Keyboard Replacement: step 4, image 1 of 3 PowerBook 3400 M3553 Keyboard Replacement: step 4, image 2 of 3 PowerBook 3400 M3553 Keyboard Replacement: step 4, image 3 of 3
      • Turn the computer over and open the display. You should see that the keyboard is loose.
      • Before attempting to remove the keyboard, note that a ribbon cable connects the keyboard to the logic board. Improper removal may damage your keyboard.
      • Slightly lift the front of the keyboard up, and slide the keyboard towards yourself.
      • Carefully lift the top half of the keyboard and pull it towards yourself.
      Ask FixBot
    3. PowerBook 3400 M3553 Keyboard Replacement: step 5, image 1 of 2 PowerBook 3400 M3553 Keyboard Replacement: step 5, image 2 of 2
      • Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port.
      • Gently remove the ribbons from its tabs.
      Ask FixBot
2 other people completed this guide.
Author
with
Michael Mondragon
415 Reputation
9 Guides authored
Cal Poly, Team 24-59, Amido Spring 2011 Member of Cal Poly, Team 24-59, Amido Spring 2011
CPSU-AMIDO-S11S24G59
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 78
All Time: 3,060
