Up to 20% off select tools
PowerBook 180 Ram Replacement
Views: 4.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
108
All Time:
4,396
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
The PowerBook 180 was one of Apple's top of the line notebook computers at around 1993. It was in high demand through all of its life, and had a selling price of about $3900 base model. This computer can run System 7 - 8.1 (through Born Again) and has a 68030 processor running at 33mhz.
    1. PowerBook 180 Ram Replacement, Ram: step 1, image 1 of 2 PowerBook 180 Ram Replacement, Ram: step 1, image 2 of 2
      • The PowerBook 180 has a removable Ni-Cad battery on the side. Before we start this repair, we need to make sure the computer does not have any power source - so you don't get shocked and the computer doesn't die.
      • Slide the battery door to the front of the computer, as directed by the arrows.
      • Pull out the battery.
      Ask FixBot
    2. PowerBook 180 Ram Replacement: step 2, image 1 of 2 PowerBook 180 Ram Replacement: step 2, image 2 of 2
      • There are 5 Torx T8 screws that hold the bottom of the PowerBook 180.
      • 4 are on the side, and one is above the modem port at the back of the computer.
      • Remove these screws.
      Ask FixBot
    3. PowerBook 180 Ram Replacement: step 3, image 1 of 2 PowerBook 180 Ram Replacement: step 3, image 2 of 2
      • Remove the bottom plate by prying up with either a flathead screwdriver or plastic object, such as a credit card.
      • Keep in mind the bottom left and right corners of the PowerBook 180 is very hard to open - you may need to use some extra force to open that side.
      • Your PowerBook 180 should look like the two pictures - with separate top and bottom halves.
      Ask FixBot
    4. PowerBook 180 Ram Replacement: step 4, image 1 of 1
      • Identify the RAM in the PowerBook 180. It is marked in red in the picture.
      • For this PowerBook, there is 4mb of Kingston RAM - a lot back in those times!
      Ask FixBot
    5. PowerBook 180 Ram Replacement: step 5, image 1 of 2 PowerBook 180 Ram Replacement: step 5, image 2 of 2
      • Remove the RAM by using a plastic object (such as a credit card) along the red marked area in the picture. The RAM is very flexible, so be very careful.
      • Now place the new RAM into the empty socket.
      • Follow these instructions in reverse order to reassemble the PowerBook 180.
      Ask FixBot
3 other people completed this guide.
Author
with
Jack Byrnes
1,244 Reputation
2 Guides authored
Master Techs Member of Master Techs
Community
337 Members
8,294 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 108
All Time: 4,396
