Up to 20% off select tools
PowerBook 180 Modem Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
101
All Time:
2,492
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 7 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
    1. PowerBook 180 Modem Replacement, Modem: step 1, image 1 of 2 PowerBook 180 Modem Replacement, Modem: step 1, image 2 of 2
      • Remove the Ni-Cad battery from the PowerBook 180.
      • Slide the arrows toward the front of the computer until the battery can slide out.
      Ask FixBot
    2. PowerBook 180 Modem Replacement: step 2, image 1 of 2 PowerBook 180 Modem Replacement: step 2, image 2 of 2
      • Removing the screws securing the bottom plate from the PowerBook 180.
      • There are 5 Torx T8 screws, 4 of which are located on the bottom and 1 on the back above the modem port.
      Ask FixBot
    3. PowerBook 180 Modem Replacement: step 3, image 1 of 2 PowerBook 180 Modem Replacement: step 3, image 2 of 2
      • Your computer should look like the two pictures after the bottom plate is removed.
      Ask FixBot
    4. PowerBook 180 Modem Replacement: step 4, image 1 of 2 PowerBook 180 Modem Replacement: step 4, image 2 of 2
      • Locate the modem board, which is next to the DC-in port.
      • There are two Torx T8 screws marked in red in the pictures. Remove these screws and pull up on the modem board to remove.
      • To reassemble your PowerBook, follow these instructions in reverse.
      Ask FixBot
3 other people completed this guide.
Author
with
Jack Byrnes
1,244 Reputation
2 Guides authored
Master Techs Member of Master Techs
Community
337 Members
8,294 Guides authored
1 Guide Comment
Great guide. Worked for me of the Powerbook 140. Thanks!
Jack - Reply Share
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 101
All Time: 2,492
