PowerA Spectra Infinity Enhanced D-pad Replacement
    1. PowerA Spectra Infinity Enhanced D-pad Replacement, Motherboard: step 1, image 1 of 2 PowerA Spectra Infinity Enhanced D-pad Replacement, Motherboard: step 1, image 2 of 2
      • Flip the controller so the back is facing up.
      Ask FixBot
    2. PowerA Spectra Infinity Enhanced D-pad Replacement: step 2, image 1 of 1
      • Remove the eight 10 mm screws from the back of the controller using a Phillips #0 screwdriver.
      Ask FixBot
    3. PowerA Spectra Infinity Enhanced D-pad Replacement: step 3, image 1 of 2 PowerA Spectra Infinity Enhanced D-pad Replacement: step 3, image 2 of 2
      • Unlock the trigger locks before removing the backplate.
      • This will make taking the plate off easier.
      • Use your fingers and carefully remove the backplate.
      Ask FixBot
    4. PowerA Spectra Infinity Enhanced D-pad Replacement: step 4, image 1 of 1
      • Remove the two 10 mm screws connecting the motherboard to the faceplate using a Phillips #0 screwdriver.
      Ask FixBot
    5. PowerA Spectra Infinity Enhanced D-pad Replacement: step 5, image 1 of 2 PowerA Spectra Infinity Enhanced D-pad Replacement: step 5, image 2 of 2
      • Use your hand to separate the motherboard from the face plate.
      Ask FixBot
    1. PowerA Spectra Infinity Enhanced D-pad Replacement, D-pad: step 6, image 1 of 2 PowerA Spectra Infinity Enhanced D-pad Replacement, D-pad: step 6, image 2 of 2
      • Remove the D-pad.
      • The buttons will fall out easily if you flip the faceplate over. You can raise the faceplate off the surface and push the D-Pad out from underneath.
      Ask FixBot
Kevyn Jorge
1,018 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 37
All Time: 823
