PowerA ProEX Xbox 360 Wired Controller Buttons Replacement
Views: 8.8K
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
113
All Time:
8,833
Comments: 0
Go to guide comments
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show you how to take apart your controller to help you access the input buttons in order to replace them. Sometimes there may be something stuck under them and all you need to do is simply remove them and clean them out.
Tools
    1. PowerA ProEX Xbox 360 Wired Controller Buttons Replacement, Buttons: step 1, image 1 of 2 PowerA ProEX Xbox 360 Wired Controller Buttons Replacement, Buttons: step 1, image 2 of 2
      • Disassemble the case by removing the 8 screws, indicated in red on the picture, that hold the back of the case to the front of the case using a J0 screwdriver.
      Ask FixBot
    2. PowerA ProEX Xbox 360 Wired Controller Buttons Replacement: step 2, image 1 of 2 PowerA ProEX Xbox 360 Wired Controller Buttons Replacement: step 2, image 2 of 2
      • The case should come apart easily. If not, use a spudger to pry the back from the front of the case.
      Ask FixBot
    3. PowerA ProEX Xbox 360 Wired Controller Buttons Replacement: step 3, image 1 of 3 PowerA ProEX Xbox 360 Wired Controller Buttons Replacement: step 3, image 2 of 3 PowerA ProEX Xbox 360 Wired Controller Buttons Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Using a pair of tweezers, remove each button and replace it with a new one.
      • A Button
      • B Button
      • X Button
      • Y Button
      Ask FixBot
15 other people completed this guide.
Rachel Ferreira
551 Reputation
1 Guide authored
UMass Dartmouth, Team 3-1, Isaacson Fall 2016 Member of UMass Dartmouth, Team 3-1, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G1
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 113
All Time: 8,833
