PowerA Fusion Controller For Xbox One Motherboard Replacement
  1. PowerA Fusion Controller For Xbox One Motherboard Replacement, Vibration Motors: step 1, image 1 of 3 PowerA Fusion Controller For Xbox One Motherboard Replacement, Vibration Motors: step 1, image 2 of 3 PowerA Fusion Controller For Xbox One Motherboard Replacement, Vibration Motors: step 1, image 3 of 3
    • Remove the nine 9.2mm screws with a JIS #1 screwdriver.
    • Remove the two bottom plastic grip covers.
    Ask FixBot
  2. PowerA Fusion Controller For Xbox One Motherboard Replacement: step 2, image 1 of 2 PowerA Fusion Controller For Xbox One Motherboard Replacement: step 2, image 2 of 2
    • Remove the two 9.2mm screws with a JIS #1 screwdriver.
    • Remove the back cover of the controller.
    Ask FixBot
  3. PowerA Fusion Controller For Xbox One Motherboard Replacement: step 3, image 1 of 2 PowerA Fusion Controller For Xbox One Motherboard Replacement: step 3, image 2 of 2
    • Take off the glue that is on top of the soldered joints with a sprudger.
    • Desolder the soldered joints of the red and black wires that are connecting the vibration motors to the motherboard.
    • Remove the vibration motors and put them aside.
    • This guide will show how to solder and desolder connections.
    Ask FixBot
  4. PowerA Fusion Controller For Xbox One Motherboard Replacement, Motherboard: step 4, image 1 of 3 PowerA Fusion Controller For Xbox One Motherboard Replacement, Motherboard: step 4, image 2 of 3 PowerA Fusion Controller For Xbox One Motherboard Replacement, Motherboard: step 4, image 3 of 3
    • Remove the five 9.2mm screws with a JIS #1 screwdriver. Indicated by the red circles.
    • Lift the motherboard and let it hang.
    Ask FixBot
  5. PowerA Fusion Controller For Xbox One Motherboard Replacement: step 5, image 1 of 2 PowerA Fusion Controller For Xbox One Motherboard Replacement: step 5, image 2 of 2
    • Remove the four 9.2mm screws that are holding the D-Pad to the controller housing. Indicated by the red circles.
    • Remove the motherboard.
    Ask FixBot
Andrea
668 Reputation
4 Guides authored
USF Tampa, Team S14-G4, Boczar Fall 2017 Member of USF Tampa, Team S14-G4, Boczar Fall 2017
USFT-BOCZAR-F17S14G4
4 Members
7 Guides authored
1 Guide Comment
Hi I have a powera fusion controler model CPFA115315-02 and I took the controller apart to clean and I forgot how the lb rb button springs go, I look on the internet and couldn't find anything. Any help would be great
Thanks
Nhgamer - Reply Share
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 49
All Time: 4,072
