Up to 20% off select tools
PowerA Fusion Controller For Xbox One Buttons Replacement
Views: 21K
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
114
All Time:
21,012
Comments: 5
3 comments on steps, 2 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Buttons are a crucial part of any controller. However, after extended use, whether regular or light, the buttons will wear down. This guide will show you how to replace the buttons on your controller. Please note that this guide is for replacing the buttons, not the circuitry attached to them. If the buttons are acting strange, for instance reading a tap as a double tap, this guide may not help.
    1. PowerA Fusion Controller For Xbox One Buttons Replacement, Buttons: step 1, image 1 of 3 PowerA Fusion Controller For Xbox One Buttons Replacement, Buttons: step 1, image 2 of 3 PowerA Fusion Controller For Xbox One Buttons Replacement, Buttons: step 1, image 3 of 3
      • Remove the (9) nine 9.2mm screws with a JIS #1 screwdriver.
      • Remove the two bottom plastic grip covers.
      Ask FixBot
    2. PowerA Fusion Controller For Xbox One Buttons Replacement: step 2, image 1 of 2 PowerA Fusion Controller For Xbox One Buttons Replacement: step 2, image 2 of 2
      • Remove the (2) two 9.2mm screws with a JIS #1 screwdriver.
      • Remove the back cover of the controller.
      Ask FixBot
    3. PowerA Fusion Controller For Xbox One Buttons Replacement: step 3, image 1 of 3 PowerA Fusion Controller For Xbox One Buttons Replacement: step 3, image 2 of 3 PowerA Fusion Controller For Xbox One Buttons Replacement: step 3, image 3 of 3
      • Remove the (5) five 9.2mm screws with a JIS #1 screwdriver.
      • Lift the motherboard and let it hang.
      Ask FixBot
    4. PowerA Fusion Controller For Xbox One Buttons Replacement: step 4, image 1 of 2 PowerA Fusion Controller For Xbox One Buttons Replacement: step 4, image 2 of 2
      • Remove the (4) four 9.2mm screws that are holding the motherboard to the controller.
      • Put the motherboard aside.
      Ask FixBot
    5. PowerA Fusion Controller For Xbox One Buttons Replacement: step 5, image 1 of 2 PowerA Fusion Controller For Xbox One Buttons Replacement: step 5, image 2 of 2
      • Remove the buttons.
      Ask FixBot
    6. PowerA Fusion Controller For Xbox One Buttons Replacement: step 6, image 1 of 2 PowerA Fusion Controller For Xbox One Buttons Replacement: step 6, image 2 of 2
      • Go back to the motherboard, and remove the buttons' gasket with a tweezler.
      Ask FixBot
10 other people completed this guide.
Author
with
Andrea
671 Reputation
4 Guides authored
USF Tampa, Team S14-G4, Boczar Fall 2017 Member of USF Tampa, Team S14-G4, Boczar Fall 2017
USFT-BOCZAR-F17S14G4
4 Members
60 Guides authored
2 Guide Comments
Okay so what do you do if by any chance one of the links that are sawdered to the mother board for the D Pad Connection cable breaks… Then what? How would I go about fixing that????
Heather Jesse - Reply Share
is there a guide to clean the bumpers out? my RB became less consistent and i'm hoping it's just because they're gunked up
urmum - Reply Share
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 114
All Time: 21,012
