PowerA Fusion Controller For Xbox One Analog Stick Replacement
    1. PowerA Fusion Controller For Xbox One Analog Stick Replacement, Analog Stick: step 1, image 1 of 3 PowerA Fusion Controller For Xbox One Analog Stick Replacement, Analog Stick: step 1, image 2 of 3 PowerA Fusion Controller For Xbox One Analog Stick Replacement, Analog Stick: step 1, image 3 of 3
      • Remove the (9) nine 9.2mm screws with a JIS #1 screwdriver.
      • Lift off the two bottom grip covers of the controller.
      Ask FixBot
    2. PowerA Fusion Controller For Xbox One Analog Stick Replacement: step 2, image 1 of 2 PowerA Fusion Controller For Xbox One Analog Stick Replacement: step 2, image 2 of 2
      • Remove the remaining (2) two 9.2mm screws holding the back cover with a JIS #1 screwdriver.
      • Carefully lift and remove the back cover of the controller.
      Ask FixBot
    3. PowerA Fusion Controller For Xbox One Analog Stick Replacement: step 3, image 1 of 3 PowerA Fusion Controller For Xbox One Analog Stick Replacement: step 3, image 2 of 3 PowerA Fusion Controller For Xbox One Analog Stick Replacement: step 3, image 3 of 3
      • Carefully remove the (5) five 9.2mm screws holding the motherboard with a JIS #1 screwdriver.
      • Lift the motherboard and rest it face up to the right of the controller front plate.
      Ask FixBot
    4. PowerA Fusion Controller For Xbox One Analog Stick Replacement: step 4, image 1 of 2 PowerA Fusion Controller For Xbox One Analog Stick Replacement: step 4, image 2 of 2
      • Remove the (4) four 9.2mm screws that are holding the motherboard to the controller.
      • Remove the motherboard from the face plate of the controller.
      Ask FixBot
    5. PowerA Fusion Controller For Xbox One Analog Stick Replacement: step 5, image 1 of 2 PowerA Fusion Controller For Xbox One Analog Stick Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Use the tweezers to unclip the (4) four metal teeth of the analog stick.
      • Use the soldering iron and desoldering braid to desolder the analog stick sensor module from the back of the motherboard.
      • Place the new analog stick sensor module and solder it back.
      • Use the How To Solder and Desolder Connections guide on iFixit to help in desoldering and soldering the analog stick sensor module.
      Ask FixBot
9 other people completed this guide.
Marjan Mehedi
191 Reputation
1 Guide authored
USF Tampa, Team S14-G4, Boczar Fall 2017 Member of USF Tampa, Team S14-G4, Boczar Fall 2017
USFT-BOCZAR-F17S14G4
4 Members
60 Guides authored
4 Guide Comments
Hi I’m looking those analog stick but I’m only finding the plastic and they are to big they are called different or something ?
Jose nobkes - Reply Share
Have you found a replacement yet? I ran into the same problem a couple of months ago, the potenciometers that I ordered did not fit into the motherboard. I even tried some other ones from a generic USB controler to no avail. Manufacturers do not report the sizes of the potenciometers, so it’s a bet everytime. I yet have to find a potentiometer that fits…
Franco Valdés - Reply Share
Any joy on purchasing these
Mike Jones - Reply Share
Has anybody found the replacement part? It’s very thin compared to other potentiometers..
Jasper G - Reply Share
Past 24 Hours: 1
Past 7 Days: 26
Past 30 Days: 146
All Time: 18,860
