Up to 20% off select tools
PowerA Enhanced Wireless Controller Action Buttons Replacement
Views: 5.9K
View statistics:
Past 24 Hours:
11
Past 7 Days:
35
Past 30 Days:
110
All Time:
5,917
Comments: 5
2 comments on steps, 3 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
There is nothing more annoying than having the buttons on your wireless controller become stuck or broken. Wireless controllers for consoles can be quite expensive and can range from $50 USD all the way to $300 USD. If you are trying to save some money by extending the life of the action buttons on your PowerA Enhanced Wireless Controller, or if you want to learn how to clean your action buttons for appearance and performance purposes, then this is the repair for you. This repair is fairly easy, and no specific skills are required for completion. By following these steps you will be back on your console in no time with your newly fixed controller that you can tell all your friends about!
    1. PowerA Enhanced Wireless Controller Action Buttons Replacement, Motherboard: step 1, image 1 of 3 PowerA Enhanced Wireless Controller Action Buttons Replacement, Motherboard: step 1, image 2 of 3 PowerA Enhanced Wireless Controller Action Buttons Replacement, Motherboard: step 1, image 3 of 3
      • Remove the battery cover by pressing down on the lever located on the top of the cover.
      • Apply pressure until it clicks out of place, and pull it off.
      Ask FixBot
    2. PowerA Enhanced Wireless Controller Action Buttons Replacement: step 2, image 1 of 1
      • Remove all eight screws using the J0 screwdriver.
      Ask FixBot
    3. PowerA Enhanced Wireless Controller Action Buttons Replacement: step 3, image 1 of 2 PowerA Enhanced Wireless Controller Action Buttons Replacement: step 3, image 2 of 2
      • Insert the iFixit opening tool into the seam and gently pry the cover plate up.
      • Remove the cover plate once it is loosened.
      Ask FixBot
    4. PowerA Enhanced Wireless Controller Action Buttons Replacement: step 4, image 1 of 3 PowerA Enhanced Wireless Controller Action Buttons Replacement: step 4, image 2 of 3 PowerA Enhanced Wireless Controller Action Buttons Replacement: step 4, image 3 of 3
      • Remove all three screws securing the motherboard using the J00 screwdriver.
      • Remove the motherboard.
      Ask FixBot
    1. PowerA Enhanced Wireless Controller Action Buttons Replacement, Action Buttons: step 5, image 1 of 3 PowerA Enhanced Wireless Controller Action Buttons Replacement, Action Buttons: step 5, image 2 of 3 PowerA Enhanced Wireless Controller Action Buttons Replacement, Action Buttons: step 5, image 3 of 3
      • Use the iFixit opening tool to lift the action button out from its place.
      • Pull the button out with your fingers.
      Ask FixBot
Author
with
Ayjah Montgomery
420 Reputation
4 Guides authored
USF Tampa, Team S1-G5, Leahy Fall 2019 Member of USF Tampa, Team S1-G5, Leahy Fall 2019
USFT-LEAHY-F19S1G5
3 Members
60 Guides authored
3 Guide Comments
Where do you buy the buttons ?? I haven’t been able to find them
Captain Chris Sherwood - Reply Share
Where can I buy the buttons?
Justinas Maraulis - Reply Share
For me, it's not the buttons, but the silicone pads for ABXY that have worn out. I've looked everywhere, but to no avail.
Radiohead - Reply Share
Past 24 Hours: 11
Past 7 Days: 35
Past 30 Days: 110
All Time: 5,917
