PowerA Enhanced 1516953-01 Motherboard Replacement
  1. PowerA Enhanced 1516953-01 Motherboard Replacement, Rear Case: step 1, image 1 of 3 PowerA Enhanced 1516953-01 Motherboard Replacement, Rear Case: step 1, image 2 of 3 PowerA Enhanced 1516953-01 Motherboard Replacement, Rear Case: step 1, image 3 of 3
    • Lay the controller face down.
    • Use a Phillips screwdriver to remove the eight 9.2 mm screws that secure the rear case.
    • Lift the rear case up and off of the chassis.
    Ask FixBot
  2. PowerA Enhanced 1516953-01 Motherboard Replacement, Motherboard: step 2, image 1 of 3 PowerA Enhanced 1516953-01 Motherboard Replacement, Motherboard: step 2, image 2 of 3 PowerA Enhanced 1516953-01 Motherboard Replacement, Motherboard: step 2, image 3 of 3
    • Remove the two 3.3 mm Phillips screws that secure the motherboard to the front case.
    • Lift the motherboard up and out of the chassis.
    Ask FixBot
Austin Fox
629 Reputation
5 Guides authored
1 Guide Comment
My controller won't turn on, what components should I check?
Emmanuel Zarate García - Reply Share
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 29
All Time: 933
