PowerA Enhanced 1516953-01 Front Case Replacement
    1. PowerA Enhanced 1516953-01 Front Case Replacement, Rear Case: step 1, image 1 of 3 PowerA Enhanced 1516953-01 Front Case Replacement, Rear Case: step 1, image 2 of 3 PowerA Enhanced 1516953-01 Front Case Replacement, Rear Case: step 1, image 3 of 3
      • Lay the controller face down.
      • Use a Phillips screwdriver to remove the eight 9.2 mm screws that secure the rear case.
      • Lift the rear case up and off of the chassis.
      Ask FixBot
    1. PowerA Enhanced 1516953-01 Front Case Replacement, Motherboard: step 2, image 1 of 3 PowerA Enhanced 1516953-01 Front Case Replacement, Motherboard: step 2, image 2 of 3 PowerA Enhanced 1516953-01 Front Case Replacement, Motherboard: step 2, image 3 of 3
      • Remove the two 3.3 mm Phillips screws that secure the motherboard to the front case.
      • Lift the motherboard up and out of the chassis.
      Ask FixBot
    1. PowerA Enhanced 1516953-01 Front Case Replacement, ABXY Buttons: step 3, image 1 of 3 PowerA Enhanced 1516953-01 Front Case Replacement, ABXY Buttons: step 3, image 2 of 3 PowerA Enhanced 1516953-01 Front Case Replacement, ABXY Buttons: step 3, image 3 of 3
      • Grip and remove each button.
      Ask FixBot
    1. PowerA Enhanced 1516953-01 Front Case Replacement, Front Case: step 4, image 1 of 3 PowerA Enhanced 1516953-01 Front Case Replacement, Front Case: step 4, image 2 of 3 PowerA Enhanced 1516953-01 Front Case Replacement, Front Case: step 4, image 3 of 3
      • Lift the bumper assembly up and out of its housing.
      • Lift the D-pad up and out of its housing.
      • Remove the ABXY buttons.
      Ask FixBot
    2. PowerA Enhanced 1516953-01 Front Case Replacement: step 5, image 1 of 2 PowerA Enhanced 1516953-01 Front Case Replacement: step 5, image 2 of 2
      • The additional advanced buttons can be poured out from the faceplate.
      Ask FixBot
Austin Fox
629 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 41
All Time: 663
