Introduction
This guide will show you how to replace the power and 3.5 mm audio adapter jacks on an iHome iP37.
Tool used on this step:iOpener$24.95
Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
Remove these four 9 mm screws from the plastic casing; you will need a Phillips #2 driver to do this.
Remove the flanged 9 mm screw from the counterweight; you will need a Phillips #2 driver to do this.
Lift and remove the counterweight.
Firmly and cautiously unplug the two white 3-pin connectors from the printed circuit board.
