Press the green release button on top of the side access panel.
Pull off the side access panel to get inside the computer.
Gently pry up the tab on the left side of the floppy drive bezel.
Swing the bezel open.
Remove the bezel from the right edge of the floppy drive.
Using a Phillips screwdriver, remove the two floppy drive shield screws.
Remove the floppy drive shield.
Disconnect the floppy drive cable from the back of the floppy drive.
Slide the floppy drive carrier and drive out of the front of the computer.
