Power Mac G5 Top Left Cooling Fan Unit Replacement
    1. Power Mac G5 Top Left Cooling Fan Unit Replacement, Side Panel: step 1, image 1 of 1
      • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
      • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
      Ask FixBot
    2. Power Mac G5 Top Left Cooling Fan Unit Replacement: step 2, image 1 of 1
      • Remove all the cables, including the power cables before opening the unit.
      Ask FixBot
    3. Power Mac G5 Top Left Cooling Fan Unit Replacement: step 3, image 1 of 2 Power Mac G5 Top Left Cooling Fan Unit Replacement: step 3, image 2 of 2
      • Lift the tab to unlock the side panel.
      • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
      Ask FixBot
    4. Power Mac G5 Top Left Cooling Fan Unit Replacement: step 4, image 1 of 3 Power Mac G5 Top Left Cooling Fan Unit Replacement: step 4, image 2 of 3 Power Mac G5 Top Left Cooling Fan Unit Replacement: step 4, image 3 of 3
      • Remove the air deflector (the clear plastic cover) by pulling on the handle.
      Ask FixBot
    1. Power Mac G5 Top Left Cooling Fan Unit Replacement, Top Left Cooling Fan Unit: step 5, image 1 of 1
      • Locate the top left cooling fan unit.
      Ask FixBot
    2. Power Mac G5 Top Left Cooling Fan Unit Replacement: step 6, image 1 of 1
      • Pull the fan straight out from its slot. You will need to remove two cables from the motherboard.
      • It may be easier to reach the cables if you remove the PCI guide (next to the fan unit) first.
      Ask FixBot
    3. Power Mac G5 Top Left Cooling Fan Unit Replacement: step 7, image 1 of 1
      • After pulling out the fan unit, the area should look like this.
      Ask FixBot
20 other people completed this guide.
Salvador Aguilar
2,550 Reputation
3 Guides authored
Cal Poly, Team 5-8, Forte Winter 2010 Member of Cal Poly, Team 5-8, Forte Winter 2010
CPSU-FORTE-W10S5G8
7 Members
132 Guides authored
1 Guide Comment
Actually you do need to remove the plastic air deflector, as the fan in question is behind it.
Tim downing - Reply Share
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 46
All Time: 20,063
