Up to 20% off select tools
Power Mac G5 RAM Replacement
Views: 43K
View statistics:
Past 24 Hours:
3
Past 7 Days:
27
Past 30 Days:
139
All Time:
43,106
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 61
61 people have marked this guide "completed." Will you be next?
Favorites: 27
27 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to replace/upgrade the RAM in your Power Mac G5.
    1. Power Mac G5 RAM Replacement, Side Panel: step 1, image 1 of 1
      • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
      • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
      Ask FixBot
    2. Power Mac G5 RAM Replacement: step 2, image 1 of 1
      • Remove all the cables, including the power cables before opening the unit.
      Ask FixBot
    3. Power Mac G5 RAM Replacement: step 3, image 1 of 2 Power Mac G5 RAM Replacement: step 3, image 2 of 2
      • Lift the tab to unlock the side panel.
      • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
      Ask FixBot
    4. Power Mac G5 RAM Replacement: step 4, image 1 of 3 Power Mac G5 RAM Replacement: step 4, image 2 of 3 Power Mac G5 RAM Replacement: step 4, image 3 of 3
      • Remove the air deflector (the clear plastic cover) by pulling on the handle.
      Ask FixBot
    1. Power Mac G5 RAM Replacement, Front Fan Assembly: step 5, image 1 of 1
      • Locate the front fan assembly.
      Ask FixBot
    2. Power Mac G5 RAM Replacement: step 6, image 1 of 1
      • Pull the fan assembly out; it should slide out easily.
      Ask FixBot
    1. Power Mac G5 RAM Replacement, RAM: step 7, image 1 of 1
      • Locate the RAM on the Power Mac G5.
      Ask FixBot
    2. Power Mac G5 RAM Replacement: step 8, image 1 of 3 Power Mac G5 RAM Replacement: step 8, image 2 of 3 Power Mac G5 RAM Replacement: step 8, image 3 of 3
      • Use your thumbs to push the RAM ejector pins to the sides.
      • The RAM module should pop up slightly.
      Ask FixBot
    3. Power Mac G5 RAM Replacement: step 9, image 1 of 1
      • Remove the RAM module from the DIMM slot.
      • The RAM modules must be installed in pairs, with one module per bank (top and bottom).
      • When reinstalling the RAM, make sure to note the notch on the DIMM slot. This notch needs to line up with the corresponding gap on the RAM module.
      Ask FixBot
61 other people completed this guide.
Author
with
Salvador Aguilar
2,550 Reputation
3 Guides authored
Cal Poly, Team 5-8, Forte Winter 2010 Member of Cal Poly, Team 5-8, Forte Winter 2010
CPSU-FORTE-W10S5G8
7 Members
132 Guides authored
2 Guide Comments
Major thing to note, you must install RAM in pairs. You can't just install one card on the top and not one on the bottom. Pairs start from the center and move outwards.
Red Rabbit 90 - Reply Share
Very helpful
Kaiden Young - Reply Share
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 139
All Time: 43,106
