Up to 20% off select tools
Power Mac G5 CD-ROM Drive Replacement
Views: 37K
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
135
All Time:
36,978
Comments: 6
4 comments on steps, 2 guide comments.
Go to guide comments
Completed: 44
44 people have marked this guide "completed." Will you be next?
Favorites: 15
15 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Use this guide to replace the CD-ROM drive in your Power Mac G5.
    1. Power Mac G5 CD-ROM Drive Replacement, Side Panel: step 1, image 1 of 1
      • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
      • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
      Ask FixBot
    2. Power Mac G5 CD-ROM Drive Replacement: step 2, image 1 of 1
      • Remove all the cables, including the power cables before opening the unit.
      Ask FixBot
    3. Power Mac G5 CD-ROM Drive Replacement: step 3, image 1 of 2 Power Mac G5 CD-ROM Drive Replacement: step 3, image 2 of 2
      • Lift the tab to unlock the side panel.
      • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
      Ask FixBot
    4. Power Mac G5 CD-ROM Drive Replacement: step 4, image 1 of 3 Power Mac G5 CD-ROM Drive Replacement: step 4, image 2 of 3 Power Mac G5 CD-ROM Drive Replacement: step 4, image 3 of 3
      • Remove the air deflector (the clear plastic cover) by pulling on the handle.
      Ask FixBot
    1. Power Mac G5 CD-ROM Drive Replacement, CD-ROM Drive: step 5, image 1 of 1
      • Locate the CD-ROM Drive on the top left corner of desktop.
      Ask FixBot
    2. Power Mac G5 CD-ROM Drive Replacement: step 6, image 1 of 3 Power Mac G5 CD-ROM Drive Replacement: step 6, image 2 of 3 Power Mac G5 CD-ROM Drive Replacement: step 6, image 3 of 3
      • Pull and rotate latches to the left.
      Ask FixBot
    3. Power Mac G5 CD-ROM Drive Replacement: step 7, image 1 of 1
      • Wiggle and pull out the CD Drive.
      Ask FixBot
    4. Power Mac G5 CD-ROM Drive Replacement: step 8, image 1 of 2 Power Mac G5 CD-ROM Drive Replacement: step 8, image 2 of 2
      • Detach the first cable from the CD-ROM drive.
      • Detach the second cable from the CD-ROM drive.
      • On some models, the IDE cable is stuck to the top of the CD-ROM with foam tape. It is easier to unplug the IDE connector from the motherboard, and de-route the IDE cable as you remove the drive.
      Ask FixBot
    5. Power Mac G5 CD-ROM Drive Replacement: step 9, image 1 of 1
      • After the CD-ROM drive is removed, the area should look like this.
      Ask FixBot
44 other people completed this guide.
Author
with
Jessica Chaidez
8,073 Reputation
3 Guides authored
Cal Poly, Team 5-8, Forte Winter 2010 Member of Cal Poly, Team 5-8, Forte Winter 2010
CPSU-FORTE-W10S5G8
7 Members
132 Guides authored
2 Guide Comments
Is it possible to use an IDE to SATA connector? I want to install my Pioneer BDR burner to potentially use the PMG5 for data disc burning only. Any thoughts?
nirv - Reply Share
Misleading title. I know how to unplug the drive, thank you very much.
I've replaced the original drive with a better one and the %#*@ tray is stuck because it's too high.
engineer2137 - Reply Share
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 135
All Time: 36,978
