Power Mac G4 M5183 Power Supply Replacement
    1. Power Mac G4 M5183 Power Supply Replacement, Opening PowerMac G4 M5183 Case: step 1, image 1 of 2 Power Mac G4 M5183 Power Supply Replacement, Opening PowerMac G4 M5183 Case: step 1, image 2 of 2
      • Pull on outer latch.
      • Lower door until it is level with your work surface.
      • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
      Ask FixBot
    1. Power Mac G4 M5183 Power Supply Replacement, Main Fan: step 2, image 1 of 2 Power Mac G4 M5183 Power Supply Replacement, Main Fan: step 2, image 2 of 2
      • Remove the screw from each of the two niches on lower part of fan using the Phillips #1 screwdriver.
      • The fan housing will still be connected to the computer by a power cable which will be removed in the next step.
      Ask FixBot
    2. Power Mac G4 M5183 Power Supply Replacement: step 3, image 1 of 1
      • Remove the power cable from the fan and detach bracing.
      Ask FixBot
    1. Power Mac G4 M5183 Power Supply Replacement, DVD-ROM Drive: step 4, image 1 of 2 Power Mac G4 M5183 Power Supply Replacement, DVD-ROM Drive: step 4, image 2 of 2
      • Removing the faceplate.
      • On the inside of the case, find the two plastic tabs.
      • While depressing the tabs, remove the faceplate by pulling and rotating outward.
      Ask FixBot
    2. Power Mac G4 M5183 Power Supply Replacement: step 5, image 1 of 1
      • Remove the two screws on the front of the drive with the Phillips #1 screwdriver.
      Ask FixBot
    3. Power Mac G4 M5183 Power Supply Replacement: step 6, image 1 of 3 Power Mac G4 M5183 Power Supply Replacement: step 6, image 2 of 3 Power Mac G4 M5183 Power Supply Replacement: step 6, image 3 of 3
      • Pull the drive out to allow access to the power and ribbon cables. Do not fully remove.
      • Remove both the power and ribbon cable.
      Ask FixBot
    1. Power Mac G4 M5183 Power Supply Replacement, Power Supply: step 7, image 1 of 2 Power Mac G4 M5183 Power Supply Replacement, Power Supply: step 7, image 2 of 2
      • Remove the 3 hex screws on the back of the case.
      • Remove the single screw on the side of the power supply casing with the Phillips #1 screwdriver.
      Ask FixBot
    2. Power Mac G4 M5183 Power Supply Replacement: step 8, image 1 of 2 Power Mac G4 M5183 Power Supply Replacement: step 8, image 2 of 2
      • Remove power cable from the logic board.
      • Remove power cable from hard drive.
      • Pull the power supply out and towards yourself.
      Ask FixBot
Finish Line
18 other people completed this guide.
Justin Petrilli
3,204 Reputation
11 Guides authored
Cal Poly, Team 13-24, Maness Winter 2010 Member of Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Members
156 Guides authored
3 Guide Comments
Had a nearby lightning strike, "scrammed" my Mac, but couldn't start it up afterwards. Google led me to the ifixit site ( where I should have gone first!) and your instructions got me going again. Granted, I had an identical, spare Macintosh so I was able to pull that power supply to replace the damaged one and not have to wait for a replacement, but your step-by-step made the swap fairly easy! Thank you! I am happy tonight!
Now to order the replacement.
Bill Pitts - Reply Share
Hello Bill, I was wondering what power supply did you order as a replacement. Getting an original would cost over $100 almost next to $200, so I want to make sure where else I can buy a good power supply. Thanks in advance.
Andrew R. - Reply Share
ditto…. like Bill I had a faithful G4 i use to archive some old OS9 files that need specific software that never went to OS X and some very basic Apache web server stuff. Mostly sleeping it went pop one day, I had replaced it a few years previously after a pram issue with a clean SH unit which i just swopped drives over, so getting sleeping beauty down from attic, following instructions I removed the power pac and in 30 minus the dead mac was running again and archive is protected
ipodista - Reply Share
Past 24 Hours: 6
Past 7 Days: 42
Past 30 Days: 151
All Time: 25,362
