Power Mac G4 M5183 Main Fan Replacement
Views: 9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
98
All Time:
8,979
Comments: 1
1 comment on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide details the removal of the main fan from the fan housing.
Tools
    1. Power Mac G4 M5183 Main Fan Replacement, Opening PowerMac G4 M5183 Case: step 1, image 1 of 2 Power Mac G4 M5183 Main Fan Replacement, Opening PowerMac G4 M5183 Case: step 1, image 2 of 2
      • Pull on outer latch.
      • Lower door until it is level with your work surface.
      • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
      Ask FixBot
    1. Power Mac G4 M5183 Main Fan Replacement, Main Fan: step 2, image 1 of 2 Power Mac G4 M5183 Main Fan Replacement, Main Fan: step 2, image 2 of 2
      • Remove the screw from each of the two niches on lower part of fan using the Phillips #1 screwdriver.
      • The fan housing will still be connected to the computer by a power cable which will be removed in the next step.
      Ask FixBot
    2. Power Mac G4 M5183 Main Fan Replacement: step 3, image 1 of 1
      • Remove the power cable from the fan and detach bracing.
      Ask FixBot
    1. Power Mac G4 M5183 Main Fan Replacement, Main Fan: step 4, image 1 of 1
      • To fully remove the fan, unfasten the 4 screws on the front of the bracing using the Phillips #2 screwdriver.
      Ask FixBot
3 other people completed this guide.
Stephen Scruggs
2,283 Reputation
2 Guides authored
Cal Poly, Team 13-24, Maness Winter 2010 Member of Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Members
156 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 98
All Time: 8,979
