Power Mac G4 M5183 Logic Board Replacement
    1. Power Mac G4 M5183 Logic Board Replacement, Opening PowerMac G4 M5183 Case: step 1, image 1 of 2 Power Mac G4 M5183 Logic Board Replacement, Opening PowerMac G4 M5183 Case: step 1, image 2 of 2
      • Pull on outer latch.
      • Lower door until it is level with your work surface.
      • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
      Ask FixBot
    1. Power Mac G4 M5183 Logic Board Replacement, Heat Sink: step 2, image 1 of 2 Power Mac G4 M5183 Logic Board Replacement, Heat Sink: step 2, image 2 of 2
      • Use the spudger to pry the clips horizontally off of the heat sink.
      • Fully remove the clips by lifting upwards.
      Ask FixBot
    2. Power Mac G4 M5183 Logic Board Replacement: step 3, image 1 of 1
      • Remove the heat sink by pulling upwards, off of the logic board.
      Ask FixBot
    1. Power Mac G4 M5183 Logic Board Replacement, RAM: step 4, image 1 of 2 Power Mac G4 M5183 Logic Board Replacement, RAM: step 4, image 2 of 2
      • Locate the RAM modules.
      • Pull side tabs outward. The RAM will pop out of the housing.
      Ask FixBot
    1. Power Mac G4 M5183 Logic Board Replacement, Graphics Card: step 5, image 1 of 2 Power Mac G4 M5183 Logic Board Replacement, Graphics Card: step 5, image 2 of 2
      • Remove the single screw with the Phillips #1 screwdriver.
      • Pull the graphics card up and out.
      Ask FixBot
    1. Power Mac G4 M5183 Logic Board Replacement, Logic Board: step 6, image 1 of 2 Power Mac G4 M5183 Logic Board Replacement, Logic Board: step 6, image 2 of 2
      • Remove the six indicated cables attached to the logic board.
      • Use the spudger to remove the modem cable as indicated.
      Ask FixBot
    2. Power Mac G4 M5183 Logic Board Replacement: step 7, image 1 of 2 Power Mac G4 M5183 Logic Board Replacement: step 7, image 2 of 2
      • Unfasten 3 Phillips screws revealed beneath the heat sink on the CPU board.
      • Carefully remove the CPU board from the Mother Board.
      • Remove the barrell nut screws from the Mother Board which held the CPU board.
      • Unfasten 3 Phillips #1 screws on Mother Board as shown in illustration 1.
      • Slide the logic board about a quarter of an inch to free it from the three retaining pins.
      • Pull upwards and outwards to fully remove the logic board.
      Ask FixBot
    3. Power Mac G4 M5183 Logic Board Replacement: step 8, image 1 of 1
      • After removing the (3) #2 philips screws, remove the (4) 1/4" hex nuts, then slide as directed and remove board.
      Ask FixBot
Finish Line
15 other people completed this guide.
Justin Petrilli
3,204 Reputation
11 Guides authored
Cal Poly, Team 13-24, Maness Winter 2010 Member of Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Members
156 Guides authored
3 Guide Comments
Chad O - Reply Share
Are the "hex nuts" under the processor board? Could you provide a close up picture of the "nuts?"
D george - Reply Share
So what is being replaced here? Wouldn’t one have to purchase a new logic board? Any info would be greatly appreciated!
Sandra Cai - Reply Share
Past 24 Hours: 2
Past 7 Days: 36
Past 30 Days: 85
All Time: 19,409
