Up to 20% off select tools
Power Mac G4 Cube Modem Replacement
Views: 5.2K
View statistics:
Past 24 Hours:
5
Past 7 Days:
20
Past 30 Days:
114
All Time:
5,198
Comments: 5
5 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Installing Modem involves removing the outer case and video card before installation.
    1. Power Mac G4 Cube Modem Replacement, Outer Case: step 1, image 1 of 3 Power Mac G4 Cube Modem Replacement, Outer Case: step 1, image 2 of 3 Power Mac G4 Cube Modem Replacement, Outer Case: step 1, image 3 of 3
      • Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
      • Push back the handle after you have taken the core out of the case.
      Ask FixBot
    2. Power Mac G4 Cube Modem Replacement: step 2, image 1 of 2 Power Mac G4 Cube Modem Replacement: step 2, image 2 of 2
      • Place the cube upside down and remove the four T10 Torx screws on the front plate. Then remove the two screws on each side.
      Ask FixBot
    3. Power Mac G4 Cube Modem Replacement: step 3, image 1 of 1
      • Slowly lift the plate off the cube and disconnect the power cord.
      Ask FixBot
    4. Power Mac G4 Cube Modem Replacement: step 4, image 1 of 1
      • Remove the four pillars from each corner.
      • The pillars should come out fairly easily.
      Ask FixBot
    1. Power Mac G4 Cube Modem Replacement, Video Card: step 5, image 1 of 1
      • Remove the screws on the back of the VGA port.
      Ask FixBot
    2. Power Mac G4 Cube Modem Replacement: step 6, image 1 of 1
      • Remove the screw attaching the video card to the logic board.
      Ask FixBot
    3. Power Mac G4 Cube Modem Replacement: step 7, image 1 of 2 Power Mac G4 Cube Modem Replacement: step 7, image 2 of 2
      • Remove power cord from the video card.
      Ask FixBot
    4. Power Mac G4 Cube Modem Replacement: step 8, image 1 of 1
      • Remove the power cord.
      • Remove the connector.
      • Remove the video card from the logic board.
      Ask FixBot
    5. Power Mac G4 Cube Modem Replacement: step 9, image 1 of 1
      • Carefully lift the video card from the logic board.
      • The video card should come out easily.
      Ask FixBot
    6. Power Mac G4 Cube Modem Replacement: step 10, image 1 of 2 Power Mac G4 Cube Modem Replacement: step 10, image 2 of 2
      • Separate the video card from the adapter.
      Ask FixBot
    1. Power Mac G4 Cube Modem Replacement, Modem: step 11, image 1 of 1
      • Remove the two screws from the modem.
      Ask FixBot
    2. Power Mac G4 Cube Modem Replacement: step 12, image 1 of 1
      • Lift modem from the Logic Board.
      • The modem should come out easily.
      Ask FixBot
3 other people completed this guide.
Author
with
Ryan Chun
1,076 Reputation
7 Guides authored
Cal Poly, Team 2-7, Johann Summer 2010 Member of Cal Poly, Team 2-7, Johann Summer 2010
CPSU-JOHANN-R10S2G7
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 114
All Time: 5,198
