Power Mac G4 Cube Hard drive Replacement
    1. Power Mac G4 Cube Hard drive Replacement, Outer Case: step 1, image 1 of 3 Power Mac G4 Cube Hard drive Replacement, Outer Case: step 1, image 2 of 3 Power Mac G4 Cube Hard drive Replacement, Outer Case: step 1, image 3 of 3
      • Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
      • Push back the handle after you have taken the core out of the case.
      Ask FixBot
    2. Power Mac G4 Cube Hard drive Replacement: step 2, image 1 of 2 Power Mac G4 Cube Hard drive Replacement: step 2, image 2 of 2
      • Place the cube upside down and remove the four T10 Torx screws on the front plate. Then remove the two screws on each side.
      Ask FixBot
    3. Power Mac G4 Cube Hard drive Replacement: step 3, image 1 of 1
      • Slowly lift the plate off the cube and disconnect the power cord.
      Ask FixBot
    4. Power Mac G4 Cube Hard drive Replacement: step 4, image 1 of 1
      • Remove the four pillars from each corner.
      • The pillars should come out fairly easily.
      Ask FixBot
    1. Power Mac G4 Cube Hard drive Replacement, Hard drive: step 5, image 1 of 1
      • Lift Airport slot.
      Ask FixBot
    2. Power Mac G4 Cube Hard drive Replacement: step 6, image 1 of 1
      • Remove the power cord from the hard drive.
      • Remove the IDE cable from the hard drive.
      • Grip the sides of the hard drive and slowly pull outward.
      Ask FixBot
    3. Power Mac G4 Cube Hard drive Replacement: step 7, image 1 of 1
      • Remove the three top screws of the hard drive use a T8 bit and remove the heat sink.
      • Carefully slide the hard drive to the open side (side without the IDE and power cables) to remove the drive.
      • Turn the drive over, remove the sled rail with a T10 driver for its two screws. Transfer the rail to the same side on the new drive.
      • Insert new hard drive.
      Ask FixBot
21 other people completed this guide.
Ryan Chun
1,076 Reputation
7 Guides authored
Cal Poly, Team 2-7, Johann Summer 2010 Member of Cal Poly, Team 2-7, Johann Summer 2010
CPSU-JOHANN-R10S2G7
5 Members
84 Guides authored
1 Guide Comment
Strictly speaking, steps 2 through 4 aren’t necessary: you can just unscrew the heatsink from the hard drive, as in step 7, and carefully lift it out (I found that tilting it toward the optical drive and then pivoting it out worked).
bobtheflyingsquirrel - Reply Share
Past 24 Hours: 4
Past 7 Days: 56
Past 30 Days: 130
All Time: 20,347
