Power Mac G4 Cube Airport Card Replacement
    1. Power Mac G4 Cube Airport Card Replacement, Remove Cube Core: step 1, image 1 of 3 Power Mac G4 Cube Airport Card Replacement, Remove Cube Core: step 1, image 2 of 3 Power Mac G4 Cube Airport Card Replacement, Remove Cube Core: step 1, image 3 of 3
      • Release the handle at the bottom of the Power Mac G4 Cube by pushing it down. Slowly pull out the cube by holding the end of the handle.
      • Watch for any parts that may become entangled with the outer case.
      • Push back the handle after you have taken the core out of the case.
      Ask FixBot
    2. Power Mac G4 Cube Airport Card Replacement, Accessing AirPort Card: step 2, image 1 of 2 Power Mac G4 Cube Airport Card Replacement, Accessing AirPort Card: step 2, image 2 of 2
      • Pull outwards on the antenna cable.
      • The cable should pop out of the card without much force.
      • Pull on the clear tab outwards to remove the existing AirPort card
      • Slide in the new AirPort card.
      • Reconnect the antenna cable.
      Ask FixBot
8 other people completed this guide.
Ryan Chun
1,076 Reputation
7 Guides authored
Cal Poly, Team 2-7, Johann Summer 2010 Member of Cal Poly, Team 2-7, Johann Summer 2010
CPSU-JOHANN-R10S2G7
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 95
All Time: 10,848
