Community-Contributed Guide
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓This guide shows you how to access the USB ports on a Power Bank #2695. When plugging in a micro-USB cable to charge your power bank and lights illuminate or only a single light illuminates, or when plugging in a USB-A to charge another device and no charging takes place, the USB ports inside the power bank may have broken free. Follow this guide to see what’s wrong, make a repair, and start charging your power bank (as shown in above video).
Video Overview
Gently squeeze the power bank with a quick grip/clamp as shown.
The power bank should separate under gentle force from the grip/clamp.
Continue to separate with your fingers or plastic pry tools.
Use a 10x loupe to inspect the back side of each USB port.
If the pins are not in contact with the pads, they will need to be resoldered.
Apply heat to the top metal of the micro-USB port.
Squeeze USB port to PCB with a pair of pliers.
Apply fresh solder to USB pin and PCB pad.
Solder should wick in, allow to cool before reassembling.
Use a small amount of plastic compatible epoxy to seal both halves back together.
