Porter-Cable PCE211 Rear Housing Replacement
    1. Porter-Cable PCE211 Rear Housing Replacement, Rear Housing: step 1, image 1 of 2 Porter-Cable PCE211 Rear Housing Replacement, Rear Housing: step 1, image 2 of 2
      • Remove the four 6 mm screws using a Phillips #2 screwdriver.
      • The screws are tight so you will need to use a bit of arm strength.
      Ask FixBot
    2. Porter-Cable PCE211 Rear Housing Replacement: step 2, image 1 of 2 Porter-Cable PCE211 Rear Housing Replacement: step 2, image 2 of 2
      • Pull the rear housing off the back of the impact wrench.
      • Be careful when removing the rear case that loose parts don't get damaged.
      Ask FixBot
Layla Berry
678 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 9
All Time: 274
