Up to 20% off select tools
Porter-Cable PCE211 Anvil Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
67
All Time:
689
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
If you need to replace the anvil of your Porter-Cable PCE211 drill, follow this guide.
Be sure to turn the drill off and unplug it from the power source prior to beginning the repair.
    1. Porter-Cable PCE211 Anvil Replacement, Gearcase: step 1, image 1 of 2 Porter-Cable PCE211 Anvil Replacement, Gearcase: step 1, image 2 of 2
      • Using the Hex Security SAE 7/32", remove the four 10 mm socket screws at the base of the gearcase.
      Ask FixBot
    2. Porter-Cable PCE211 Anvil Replacement: step 2, image 1 of 3 Porter-Cable PCE211 Anvil Replacement: step 2, image 2 of 3 Porter-Cable PCE211 Anvil Replacement: step 2, image 3 of 3
      • Grip the body of the impact wrench with one hand and the gearcase in the other and firmly pull to remove it.
      • Be careful about any loose parts when removing the head.
      Ask FixBot
    1. Porter-Cable PCE211 Anvil Replacement, Anvil: step 3, image 1 of 3 Porter-Cable PCE211 Anvil Replacement, Anvil: step 3, image 2 of 3 Porter-Cable PCE211 Anvil Replacement, Anvil: step 3, image 3 of 3
      • Firmly pull the to remove drill bit holder also known as the anvil.
      • Before replacing the anvil, lubricate the base for the best performance.
      Ask FixBot
Author
with
Layla Berry
696 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 67
All Time: 689
