Up to 20% off select tools
Porter Cable 690LR Base Panel Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
85
All Time:
741
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show you the steps to replace the base panel on the Porter Cable 690LR Router. It's quite difficult to mess this one up. Just make sure when you replace the base panel you screw it back in right side up.
    1. Porter Cable 690LR Base Panel Replacement, Base: step 1, image 1 of 2 Porter Cable 690LR Base Panel Replacement, Base: step 1, image 2 of 2
      • Undo the black latch located on the base of the router by pulling upwards from underneath it.
      Ask FixBot
    2. Porter Cable 690LR Base Panel Replacement: step 2, image 1 of 2 Porter Cable 690LR Base Panel Replacement: step 2, image 2 of 2
      • Twist the base off the router.
      • You may need to jiggle the base of the router slightly.
      Ask FixBot
    1. Porter Cable 690LR Base Panel Replacement, Base Panel: step 3, image 1 of 2 Porter Cable 690LR Base Panel Replacement, Base Panel: step 3, image 2 of 2
      • Orient the base so the black circular plate is facing you. Locate the three silver screw heads.
      • Use a flathead screwdriver to take off the three 10 mm screws.
      Ask FixBot
Author
with
Emma Stine
273 Reputation
2 Guides authored
Cal Poly, Team 20-7, Livingston Fall 2016 Member of Cal Poly, Team 20-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G7
4 Members
72 Guides authored
1 Guide Comment
Aynı ürünü kullanıyorum..! Son birkaç yıldır Porter Cable ürünlerini kullanıyorum
Ancak bunu bu siteden satın aldım - https://www.raptorsupplies.com/b/porter-...
Omer Polat - Reply Share
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 85
All Time: 741
