Porsche 997.1 PCM 2.1 Screen Replacement
  1. Porsche 997.1 PCM 2.1 Screen Replacement, Starting out: step 1, image 1 of 1
    • This guide only shows the steps to change the screen once the PCM has been removed from the car. There are lots of great You Tube videos that cover the removal process.
  2. Porsche 997.1 PCM 2.1 Screen Replacement, Remove the two access screws: step 2, image 1 of 1
    • As the top of the unit says: the PCM should not be opened. Remove the two Torx T9 machine screws
  3. Porsche 997.1 PCM 2.1 Screen Replacement, Splitting the PCM top from the bottom: step 3, image 1 of 2 Porsche 997.1 PCM 2.1 Screen Replacement, Splitting the PCM top from the bottom: step 3, image 2 of 2
    • Carefully split the PCM case in half. There are several interlocking tabs, but essentially open from the front to the back like an oyster shell. The top half can be set behind the unit as shown in the second photo.
    • Do not use excessive force, the CD unit is in the top half and joined to the motherboard via a PC cable.
  4. Porsche 997.1 PCM 2.1 Screen Replacement, Separating the CD unit from the main chassis: step 4, image 1 of 1
    • Use a plastic spudger to disconnect the PC ribbon cable joining the CD player to the motherboard and place the CD unit safely to one side.
  5. Porsche 997.1 PCM 2.1 Screen Replacement, Removing the torx fasteners connecting the facia with the main chassis: step 5, image 1 of 2 Porsche 997.1 PCM 2.1 Screen Replacement, Removing the torx fasteners connecting the facia with the main chassis: step 5, image 2 of 2
    • Remove the two Torx T9 machine screws that attach the front facia to the chassis. There is one screw either side as shown in the photos.
  6. Porsche 997.1 PCM 2.1 Screen Replacement, Disconnecting the ribbon cable: step 6, image 1 of 2 Porsche 997.1 PCM 2.1 Screen Replacement, Disconnecting the ribbon cable: step 6, image 2 of 2
    • Open the ribbon cable lock (there is probably a proper name for it) and remove the ribbon cable on the left hand side of the unit.
  7. Porsche 997.1 PCM 2.1 Screen Replacement, Identifying the tab retainers keeping the facia connected to the chassis: step 7, image 1 of 3 Porsche 997.1 PCM 2.1 Screen Replacement, Identifying the tab retainers keeping the facia connected to the chassis: step 7, image 2 of 3 Porsche 997.1 PCM 2.1 Screen Replacement, Identifying the tab retainers keeping the facia connected to the chassis: step 7, image 3 of 3
    • This is the most difficult step in the process. Firstly, identify the four tab retainers holding the facia to the chassis. The three photos show them all.
  8. Porsche 997.1 PCM 2.1 Screen Replacement, Using a metal spludger to disconnect the retaining tabs: step 8, image 1 of 2 Porsche 997.1 PCM 2.1 Screen Replacement, Using a metal spludger to disconnect the retaining tabs: step 8, image 2 of 2
    • A curved metal spudger seemed to work well for this. Each tab had to be carefully leveraged up to disconnect them from the facia.
  9. Porsche 997.1 PCM 2.1 Screen Replacement, Prying the facia away from the chassis: step 9, image 1 of 3 Porsche 997.1 PCM 2.1 Screen Replacement, Prying the facia away from the chassis: step 9, image 2 of 3 Porsche 997.1 PCM 2.1 Screen Replacement, Prying the facia away from the chassis: step 9, image 3 of 3
    • Working around the tabs, the facia can be gently pried off the chassis. This requires patience and care.
    • When the facia has come apart from the chassis, care is required as the two are still connected with another two PC ribbon cables.
    • The third photo shows the fixed connector which needs careful realignment on reassembly.
  10. Porsche 997.1 PCM 2.1 Screen Replacement, Disconnect the PC ribbon cables joining the facia to the chassis: step 10, image 1 of 2 Porsche 997.1 PCM 2.1 Screen Replacement, Disconnect the PC ribbon cables joining the facia to the chassis: step 10, image 2 of 2
    • Use a spudger to disconnect the PC ribbon cables connecting the facia to the chassis.
  11. Porsche 997.1 PCM 2.1 Screen Replacement, Identify all the torx T9 fasteners on the facia: step 11, image 1 of 2 Porsche 997.1 PCM 2.1 Screen Replacement, Identify all the torx T9 fasteners on the facia: step 11, image 2 of 2
    • The two halves of the facia are connected using 14 torx T9 self tapping screws.
    • If you only find thirteen, you have missed one of the little blighters. If you only find twelve.. well see previous comment but add one to the list of missed fasteners. The back of the casting is show as it better indicate the fastener placements.
  12. Porsche 997.1 PCM 2.1 Screen Replacement, Disconnect the remaining tabs holding the facia together: step 12, image 1 of 1
    • Once all 14 torx T9 screws have been found and undone, there are two tabs remaining that need to be disconnected before the facia comes apart.
    • Once the two halves are separated, the three ribbon connectors need to be carefully threaded through the holes in the back of the facia casting.
  13. Porsche 997.1 PCM 2.1 Screen Replacement, Removing the screen carrier: step 13, image 1 of 3 Porsche 997.1 PCM 2.1 Screen Replacement, Removing the screen carrier: step 13, image 2 of 3 Porsche 997.1 PCM 2.1 Screen Replacement, Removing the screen carrier: step 13, image 3 of 3
    • The first photo shows the location of the screen carrier clips. Once these are released with a spudger, the screen carrier can be released, the small grey ribbon connector can be gently pushed out the way when this is done.
  14. Porsche 997.1 PCM 2.1 Screen Replacement, Separating the screen from the screen carrier: step 14, image 1 of 3 Porsche 997.1 PCM 2.1 Screen Replacement, Separating the screen from the screen carrier: step 14, image 2 of 3 Porsche 997.1 PCM 2.1 Screen Replacement, Separating the screen from the screen carrier: step 14, image 3 of 3
    • Use a spudger to disconnect the orange/white cable. This only reconnects one way. Unhook the orange/white cable from the screen carrier and the carrier will lift away from the screen.
  15. Porsche 997.1 PCM 2.1 Screen Replacement, Disconnect the screen ribbon cable: step 15, image 1 of 1
    • Disconnect the ribbon cable using the same technique that was done at the other end, where it connects to the motherboard.
  16. Porsche 997.1 PCM 2.1 Screen Replacement, Transfer the ribbon cable: step 16, image 1 of 1
    • Transfer the ribbon cable to the new screen.
5 other people completed this guide.
m330cameron
403 Reputation
1 Guide authored
2 Guide Comments
This guide saved me a lot of money. Follow it and don’t be scared. It’s actually a fairly easy job.
Bill Berry - Reply Share
guide worked great, thank you! one additional caution. the pins on the data ribbon connecting the display to the electronics are very fragile and can easily separate from the plastic. when reinserting the ribbon into the socket use great care not to bend the pins. thankfully I was able to straighten the pins by hand and make a good connection, otherwise I was preparing to shopping for a replacement ribbon on amazon :)
douirc - Reply Share
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 84
All Time: 4,136
