Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement
  1. Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Removing the Battery Cover: step 1, image 1 of 3 Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Removing the Battery Cover: step 1, image 2 of 3 Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Removing the Battery Cover: step 1, image 3 of 3
    • Hold the mouthpiece of the handset and locate the lock-unlock text.
    • Twist the battery cover counterclockwise from the "lock" to the "unlock" position.
    Ask FixBot
  2. Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Disconnecting the Battery Wire: step 2, image 1 of 3 Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Disconnecting the Battery Wire: step 2, image 2 of 3 Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Disconnecting the Battery Wire: step 2, image 3 of 3
    • To disconnect the battery pack wire from the phone, squeeze the tab against the connector and pull connector straight up from the socket.
    Ask FixBot
  3. Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Removing the Battery Pack: step 3, image 1 of 3 Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Removing the Battery Pack: step 3, image 2 of 3 Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Removing the Battery Pack: step 3, image 3 of 3
    • Pull the battery from the battery compartment.
    • You may need to gently wiggle the battery back and forth in its compartment to help loosen it.
    Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 42
All Time: 1,227
