Up to 20% off select tools
Polycom SoundStation Button Pad Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
85
All Time:
1,396
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
Replacing or adjusting the unresponsive buttons will allow you to use the phone properly if it seems that the buttons or stuck or damaged.
    1. Polycom SoundStation Button Pad Replacement, Back Housing: step 1, image 1 of 1
      • Flip the device over. Using a Phillips #00 screwdriver, remove the black 10mm screw on each three legs of the phone.
      • Using a Phillips #00 screwdriver, remove the two silver 7mm screws as pictured.
      Ask FixBot
    2. Polycom SoundStation Button Pad Replacement: step 2, image 1 of 2 Polycom SoundStation Button Pad Replacement: step 2, image 2 of 2
      • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing off!
      Ask FixBot
    1. Polycom SoundStation Button Pad Replacement, Button Pad: step 3, image 1 of 1
      • Remove the rubber keyboard.
      Ask FixBot
Author
with
Cali Nowak Credit
431 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 85
All Time: 1,396
