Up to 20% off select tools
Polycom SoundStation Back Housing Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
83
All Time:
1,855
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
Taking off the back of this phone will allow you to look at or replace all of the pieces inside this device. This is a prerequisite guide for any other replacement you would like to accomplish with your SoundStation.
    1. Polycom SoundStation Back Housing Replacement, Back Housing: step 1, image 1 of 1
      • Flip the device over. Using a Phillips #00 screwdriver, remove the black 10mm screw on each three legs of the phone.
      • Using a Phillips #00 screwdriver, remove the two silver 7mm screws as pictured.
      Ask FixBot
    2. Polycom SoundStation Back Housing Replacement: step 2, image 1 of 2 Polycom SoundStation Back Housing Replacement: step 2, image 2 of 2
      • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing off!
      Ask FixBot
Author
with
Cali Nowak Credit
431 Reputation
4 Guides authored
1 Guide Comment
thanks for this - the 7mm were under footpads so I couldn’t see them. cover now off, keyboard dried of coffee and working fine again!!
J M - Reply Share
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 83
All Time: 1,855
