Introduction
The Polk Omni S2 has two radiators adjacent to each of its drivers. The radiators aren't powered on their own, but are vibrated by small air pressure changes inside the speaker as the drivers vibrate. Radiators increase the volume of lower frequencies, amplifying the bass. It may be hard to notice a malfunctioning radiator, but if your radiator has apparent physical damage (punctured, etc.), you may want to replace it.
This guide is for the left radiator (when looking at the front of the device).
Use a Phillips #1 screwdriver to remove the five 9.5 mm screws securing the radiator.
