Polk MagniFi Soundbar Bluetooth Cable Replacement
  1. Polk MagniFi Soundbar Bluetooth Cable Replacement, Bluetooth Cable: step 1, image 1 of 3 Polk MagniFi Soundbar Bluetooth Cable Replacement, Bluetooth Cable: step 1, image 2 of 3 Polk MagniFi Soundbar Bluetooth Cable Replacement, Bluetooth Cable: step 1, image 3 of 3
    • To reveal the control button, first, carefully remove the front cover of the Sound Bar.
    • Use the plastic iFixit opening tool to lift up the front surface. Insert the tool between the cover and the body to open it.
    • After the cover is fully removed, it will be able to see the interior speaker.
    • Carefully unscrew all 16 screws to release the panel.
    • There are total 16 screws that secures the panel onto the cover. Each screw is approximately 1.50 centimeter.
    Ask FixBot
  2. Polk MagniFi Soundbar Bluetooth Cable Replacement: step 2, image 1 of 3 Polk MagniFi Soundbar Bluetooth Cable Replacement: step 2, image 2 of 3 Polk MagniFi Soundbar Bluetooth Cable Replacement: step 2, image 3 of 3
    • To remove the cover behind the control buttons, insert the iFixit opening tool between the cover and the body
    • Push the opening tool along the edge of the cover to fully open it.
    Ask FixBot
  3. Polk MagniFi Soundbar Bluetooth Cable Replacement: step 3, image 1 of 1
    • Underneath the cover, there is a black panel screwed onto the cover with two sets of wires plugged into it.
    Ask FixBot
  4. Polk MagniFi Soundbar Bluetooth Cable Replacement: step 4, image 1 of 2 Polk MagniFi Soundbar Bluetooth Cable Replacement: step 4, image 2 of 2
    • Grasp the wire firmly close to the base and pull straight out. Repeat this for the other end of the wire.
    • This wire is easily broken. Handle with care.
    Ask FixBot
[deleted]
695 Reputation
4 Guides authored
1 Guide Comment
Can you pair it with Beats headphones.?
wayne rivers - Reply Share
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 25
All Time: 2,818
