Polaroid i533 Zoom Lens Replacement
    1. Polaroid i533 Zoom Lens Replacement, Zoom Lens: step 1, image 1 of 3 Polaroid i533 Zoom Lens Replacement, Zoom Lens: step 1, image 2 of 3 Polaroid i533 Zoom Lens Replacement, Zoom Lens: step 1, image 3 of 3
      • Use a Phillips #00 driver to remove four screws (3mm) on the left side of the camera. Keep all screws for reassembly.
      • Directly on the bottom of the camera there are 3 screws, unscrew all with a Phillips #00 driver.
      • Unscrew two screws on the right side of the camera with a Phillips #00 driver.
      Ask FixBot
    2. Polaroid i533 Zoom Lens Replacement, Opening back cover: step 2, image 1 of 2 Polaroid i533 Zoom Lens Replacement, Opening back cover: step 2, image 2 of 2
      • Locate the battery door on the bottom of the camera. Then slide the battery door open using the iFixit opening tool.
      • Gently open the back cover of camera.
      • Do not pull the cover off completely, because it is still attached to the logic board.
      Ask FixBot
    3. Polaroid i533 Zoom Lens Replacement: step 3, image 1 of 3 Polaroid i533 Zoom Lens Replacement: step 3, image 2 of 3 Polaroid i533 Zoom Lens Replacement: step 3, image 3 of 3
      • Locate where the LCD screen ribbon is attached to the logic board.
      • Using the ifixit opening tool, push the black tab connecting the LCD screen ribbon to the logic board away from you.
      • Gently pull the ribbon away from the logic board with thumb and index fingers.
      Ask FixBot
    4. Polaroid i533 Zoom Lens Replacement, Removing screws on logic board: step 4, image 1 of 2 Polaroid i533 Zoom Lens Replacement, Removing screws on logic board: step 4, image 2 of 2
      • Using the Phillips #00 screwdriver, unscrew and remove the (3mm) screw on the bottom of the logic board above the tripod mount. Keep the screw for reassembly.
      • Gently pull the front of the case off.
      Ask FixBot
    5. Polaroid i533 Zoom Lens Replacement: step 5, image 1 of 2 Polaroid i533 Zoom Lens Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Locate the black patch covering the ribbon that connects the zoom lens to the logic board.
      • Carefully remove the black patch using tweezers.
      Ask FixBot
    6. Polaroid i533 Zoom Lens Replacement, Removing zoom lens ribbon: step 6, image 1 of 2 Polaroid i533 Zoom Lens Replacement, Removing zoom lens ribbon: step 6, image 2 of 2
      • Using tweezers gently lift the black tab that holds the zoom lens ribbon in place.
      • Gently remove the zoom lens ribbon.
      Ask FixBot
    7. Polaroid i533 Zoom Lens Replacement: step 7, image 1 of 2 Polaroid i533 Zoom Lens Replacement: step 7, image 2 of 2
      • Use the Phillips #00 screwdriver and unscrew then remove the three (3mm) screws shown on the back of the logic board.
      • On the left side of the logic board use the same screwdriver. Unscrew and remove the 3mm screw. Keep all screws for reassembly.
      Ask FixBot
    8. Polaroid i533 Zoom Lens Replacement: step 8, image 1 of 2 Polaroid i533 Zoom Lens Replacement: step 8, image 2 of 2
      • It is now safe for you to remove the zoom lens.
      • To reassemble the device, follow these steps in reverse.
      Ask FixBot
To reassemble your device, follow these steps in reverse order.
Aric Champagne
18 Reputation
1 Guide authored
Cal Poly, Team 3-4, Johann Summer 2010 Member of Cal Poly, Team 3-4, Johann Summer 2010
CPSU-JOHANN-R10S3G4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 42
All Time: 3,324
