Polaroid a520 LCD Screen Replacement
    1. Polaroid a520 LCD Screen Replacement, Battery: step 1, image 1 of 2 Polaroid a520 LCD Screen Replacement, Battery: step 1, image 2 of 2
      • Place your thumb on the battery cover and push left towards the arrow.
      • The cover will release and pop open.
      Ask FixBot
    2. Polaroid a520 LCD Screen Replacement: step 2, image 1 of 1
      • Remove the batteries from the camera.
      Ask FixBot
    1. Polaroid a520 LCD Screen Replacement, Casing: step 3, image 1 of 1
      • Remove four 3 mm screws on the right side of the camera using a Phillips #1 screwdriver.
      • This will release the front and back casings.
      Ask FixBot
    2. Polaroid a520 LCD Screen Replacement: step 4, image 1 of 1
      • Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
      • Repeat this step for the back casing.
      Ask FixBot
    1. Polaroid a520 LCD Screen Replacement, LCD Screen: step 5, image 1 of 1
      • Under the screen, locate the black plastic strip that sits above the white plastic strip.
      Ask FixBot
    2. Polaroid a520 LCD Screen Replacement: step 6, image 1 of 1
      • Pull both sides of the black piece upward-about a mm.
      • The black plastic piece is not meant to come all the way off, just enough to release the screen.
      • Once the piece is lifted carefully slide the screen out of the slot.
      Ask FixBot
Dani
21 Reputation
7 Guides authored
Cal Poly, Team 3-3, Johann Summer 2010 Member of Cal Poly, Team 3-3, Johann Summer 2010
CPSU-JOHANN-R10S3G3
2 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 30
All Time: 2,122
