Up to 20% off select tools
Polaroid Z2300 Control Panel Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
64
All Time:
987
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide is intended for users who have Polaroid Z2300 with a malfunctioning control panel.
    1. Polaroid Z2300 Control Panel Replacement, Control Panel Replacement: step 1, image 1 of 3 Polaroid Z2300 Control Panel Replacement, Control Panel Replacement: step 1, image 2 of 3 Polaroid Z2300 Control Panel Replacement, Control Panel Replacement: step 1, image 3 of 3
      • Locate and remove the two 2.5 mm long screws on the bottom of the camera.
      • Screw head: JIS J00
      • The screws are very small, be careful not to strip or lose them!
      Ask FixBot
    2. Polaroid Z2300 Control Panel Replacement: step 2, image 1 of 3 Polaroid Z2300 Control Panel Replacement: step 2, image 2 of 3 Polaroid Z2300 Control Panel Replacement: step 2, image 3 of 3
      • Once the two screws are removed, flip the camera to back side up.
      • Use a plastic opening tool to disengage the outer plastic trim until it can be safely removed.
      Ask FixBot
    3. Polaroid Z2300 Control Panel Replacement: step 3, image 1 of 2 Polaroid Z2300 Control Panel Replacement: step 3, image 2 of 2
      • Use a plastic opening tool to pop the control panel off, it should be easy to lift up and remove.
      Ask FixBot
Author
with
Bradley Marcum
217 Reputation
2 Guides authored
IUPUI, Team S2-G1, Harley Fall 2018 Member of IUPUI, Team S2-G1, Harley Fall 2018
IUPUI-HARLEY-F18S2G1
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 64
All Time: 987
