Polaroid Sun 600 LMS Lens Replacement
  1. Polaroid Sun 600 LMS Lens Replacement, Lens: step 1, image 1 of 2 Polaroid Sun 600 LMS Lens Replacement, Lens: step 1, image 2 of 2
    • Move film door slide on the left side of camera forward.
    • Pull film door open.
    Ask FixBot
  2. Polaroid Sun 600 LMS Lens Replacement: step 2, image 1 of 2 Polaroid Sun 600 LMS Lens Replacement: step 2, image 2 of 2
    • Open the flash assembly by holding the sides of the top piece of the camera and pushing up gently until it snaps into place.
    • If your camera is old or dirty, it may take more force to open the flash assembly.
    Ask FixBot
  3. Polaroid Sun 600 LMS Lens Replacement: step 3, image 1 of 2 Polaroid Sun 600 LMS Lens Replacement: step 3, image 2 of 2
    • Use a spudger on each side to separate the flash segment from the main body.
    • Be careful not to do this too hard because you may pull out the connecting wires.
    Ask FixBot
  4. Polaroid Sun 600 LMS Lens Replacement: step 4, image 1 of 2 Polaroid Sun 600 LMS Lens Replacement: step 4, image 2 of 2
    • Use several plastic opening tools around the edges of the camera's body to separate it from the plastic frame.
    Ask FixBot
  5. Polaroid Sun 600 LMS Lens Replacement: step 5, image 1 of 2 Polaroid Sun 600 LMS Lens Replacement: step 5, image 2 of 2
    • Place left hand on the gray section and right hand on the black section.
    • Pull the sections apart.
    Ask FixBot
  6. Polaroid Sun 600 LMS Lens Replacement: step 6, image 1 of 2 Polaroid Sun 600 LMS Lens Replacement: step 6, image 2 of 2
    • Carefully remove the damaged lens from the interior of the camera.
    • Replace with a new lens.
    Ask FixBot
Ian Hosek
365 Reputation
1 Guide authored
Cal Poly, Team 3-18, Maness Winter 2010 Member of Cal Poly, Team 3-18, Maness Winter 2010
CPSU-MANESS-W10S3G18
4 Members
6 Guides authored
1 Guide Comment
How could I clean the viewfinder? I have a little bit of dust stuck behind the lens
Corinthia - Reply Share
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 72
All Time: 11,764
