Polaroid S10 Battery Replacement
    1. Polaroid S10 Battery Replacement, Removing the backcover: step 1, image 1 of 3 Polaroid S10 Battery Replacement, Removing the backcover: step 1, image 2 of 3 Polaroid S10 Battery Replacement, Removing the backcover: step 1, image 3 of 3
      • Place an opening pick between the volume button and the back cover.
      • More than one pick may be needed, but avoid placing more than two picks in the same space.
      • Excessive force on the pick will break the volume button.
      • Carefully remove the back cover using the metal spudger.
      • It is normal to hear a snapping noise due to the plastic tabs on the back cover.
      Ask FixBot
    1. Polaroid S10 Battery Replacement, Battery: step 2, image 1 of 3 Polaroid S10 Battery Replacement, Battery: step 2, image 2 of 3 Polaroid S10 Battery Replacement, Battery: step 2, image 3 of 3
      • Use a spudger to carefully remove the tape nearest to the battery.
      • Use caution while removing tape. Too much force can damage the device.
      • Gently use the spudger to remove the battery out of place by wedging it out from the bottom.
      • Do not move the battery. Moving it could cause the cables to be ripped out.
      Ask FixBot
    1. Polaroid S10 Battery Replacement, Battery Connection: step 3, image 1 of 2 Polaroid S10 Battery Replacement, Battery Connection: step 3, image 2 of 2
      • Carefully desolder the 2 wires that connect the battery to the motherboard.
      • Do not touch the soldering iron to the motherboard or the LCD screen.
      Ask FixBot
Follow these instructions to reassemble your device.
James
367 Reputation
3 Guides authored
1 Guide Comment
Can't open the %#*@ thing!!!!!!!!!!
tosaguys - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 5,650
