Polaroid PTAB7XC Power Button Replacement
    1. Polaroid PTAB7XC Power Button Replacement, Power Button: step 1, image 1 of 2 Polaroid PTAB7XC Power Button Replacement, Power Button: step 1, image 2 of 2
      • Remove the two 7 mm screws on the top of the device using a J00 Phillips screwdriver by turning them counterclockwise.
      • If the screw heads have corroded or been stripped, it may be necessary to use a larger screwdriver head, such as the J0.
      Ask FixBot
    2. Polaroid PTAB7XC Power Button Replacement: step 2, image 1 of 2 Polaroid PTAB7XC Power Button Replacement: step 2, image 2 of 2
      • Pry the seam between the screen and the case on all four sides with a large plastic opening tool until the plastic case comes off.
      • The plastic case is now free from the device.
      • The plastic power button may or may not fall out at this point. There is no problem if it does.
      Ask FixBot
    3. Polaroid PTAB7XC Power Button Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to push on the side of the black plastic power button that is outside of the device case until the button is as far in as possible.
      • Pull on the part of the broken power button that is exposed on the inside of the device case using tweezers until the button itself comes loose of the case.
      • The power button is now replaceable.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 20
All Time: 1,171
