Polaroid PMID701i 10 Battery Replacement
    1. Polaroid PMID701i 10 Battery Replacement, Panel: step 1, image 1 of 2 Polaroid PMID701i 10 Battery Replacement, Panel: step 1, image 2 of 2
      • Turn off and unplug the device before starting replacement.
      • Flip the device so that the screen faces down, with the back facing up.
      • The back panel attaches to the device with four 4.0mm long screws, one at each corner, indicated by the red circles in the picture.
      • Unscrew the four screws with a PH000 screwdriver.
      Ask FixBot
    2. Polaroid PMID701i 10 Battery Replacement: step 2, image 1 of 2 Polaroid PMID701i 10 Battery Replacement: step 2, image 2 of 2
      • Flip the device over so that the screen faces up, and the back faces down.
      • Separate the front panel using the Opening Tool on a corner to create an opening.
      • Removing the frame for the first time may take a significant amount of force.
      • Run the tool along the seams of the device to open up all the sides.
      Ask FixBot
    3. Polaroid PMID701i 10 Battery Replacement: step 3, image 1 of 1
      • Removing the panel too quickly may damage the cable that attaches parts between the two panels.
      • Gently lift the top panel from the bottom panel.
      Ask FixBot
    4. Polaroid PMID701i 10 Battery Replacement: step 4, image 1 of 2 Polaroid PMID701i 10 Battery Replacement: step 4, image 2 of 2
      • The flexible flat cables (FFC) attach to parts in the bottom panel with zero insertion force (ZIF) connectors.
      • Use the Opening tool to flip up the black retaining flap on the smaller connector.
      • Gently lift the cable, parallel to the panel, to detach it.
      Ask FixBot
    5. Polaroid PMID701i 10 Battery Replacement: step 5, image 1 of 2 Polaroid PMID701i 10 Battery Replacement: step 5, image 2 of 2
      • Use the Opening tool to flip up the black retaining flap on the larger connector.
      Ask FixBot
    1. Polaroid PMID701i 10 Battery Replacement, Battery: step 6, image 1 of 1
      • The battery is wrapped with tape. It is attached to the back plastic panel by glue.
      • The battery may bend if detached using a spudger or other small tool.
      • Grip the the battery by hand.
      • Due to the glue and shape of the battery it, it may take a significant amount of force to lift it.
      • Lift the battery, by hand, to remove it from the glue and panel.
      Ask FixBot
    2. Polaroid PMID701i 10 Battery Replacement: step 7, image 1 of 1
      • The battery attaches to the motherboard with two wires, one red and one black.
      • Desolder the wires from the motherboard. For detailed information, refer to the Solder and Desolder guide.
      Ask FixBot
    3. Polaroid PMID701i 10 Battery Replacement: step 8, image 1 of 1
      • Gently remove the battery, with the wires, from the panel and motherboard completely.
      Ask FixBot
2 other people completed this guide.
Amy Li
651 Reputation
5 Guides authored
Baylor, Team 3-4, Whitney Spring 2017 Member of Baylor, Team 3-4, Whitney Spring 2017
BU-WHITNEY-S17S3G4
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 85
All Time: 629
